6 hours ago, Anvar Zalibekov said:
opkg install homeassistant --force-overwrite
TheBB такое указывал ранее для установки. У меня такое работает.
да нет, homeassistant ставится без ошибок.
opkg remove homeassistant
не помогает, естественно, те же ошибки
Unable to install package zigpy-znp==0.11.4: error: subprocess-exited-with-error × pip subprocess to install build dependencies did not run successfully. │ exit code: 1 ╰─> [58 lines of output] Collecting maturin<2.0,>=1.0 Using cached maturin-1.3.1.tar.gz (176 kB) Installing build dependencies: started Installing build dependencies: still running... Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Building wheels for collected packages: maturin Building wheel for maturin (pyproject.toml): started Building wheel for maturin (pyproject.toml): finished with status 'error' error: subprocess-exited-with-error × Building wheel for maturin (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [35 lines of output] /opt/tmp/pip-build-env-3j49654x/overlay/lib/python3.11/site-packages/setuptools/config/_apply_pyprojecttoml.py:80: SetuptoolsWarning: `install_requires` overwritten in `pyproject.toml` (dependencies) corresp(dist, value, root_dir) running bdist_wheel running build running build_py creating build creating build/lib.linux-mips-cpython-311 creating build/lib.linux-mips-cpython-311/maturin copying maturin/import_hook.py -> build/lib.linux-mips-cpython-311/maturin copying maturin/__init__.py -> build/lib.linux-mips-cpython-311/maturin copying maturin/__main__.py -> build/lib.linux-mips-cpython-311/maturin running egg_info creating maturin.egg-info writing maturin.egg-info/PKG-INFO writing dependency_links to maturin.egg-info/dependency_links.txt writing requirements to maturin.egg-info/requires.txt writing top-level names to maturin.egg-info/top_level.txt writing manifest file 'maturin.egg-info/SOURCES.txt' reading manifest file 'maturin.egg-info/SOURCES.txt' reading manifest template 'MANIFEST.in' warning: no files found matching '*.json' under directory 'src/python_interpreter' writing manifest file 'maturin.egg-info/SOURCES.txt' running build_ext running build_rust error: can't find Rust compiler If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler. To update pip, run: pip install --upgrade pip and then retry package installation.
Logger: homeassistant.components.dhcp
Source: components/dhcp/__init__.py:474
Integration: DHCP Discovery (documentation, issues)
First occurred: 6:38:04 PM (1 occurrences)
Last logged: 6:38:04 PM
Cannot watch for dhcp packets without a functional packet filter: libpcap is not available. Cannot compile filter !
В этой теме эти ошибки уже были у форумчан, решения, вроде, никто так и не нашел.
В 29.10.2023 в 14:32, VitalyS сказал:
Остается ошибка с libpcap, несмотря на то, что libpcap установлен
https://github.com/Entware/Entware/wiki/Self-installation-of-python-modules :
To install python modules that have C extensions install gcc as described in Using-GCC-for-native-compilation.
В 25.10.2023 в 11:21, Руслан З сказал:
Полноценный ESPHome на роутере не завелся.
К сожалению, модуль для mipsel я так и не нашел, не там искал, или просто что-то не понимаю.
Его просто нет. Нужен нативный кросс-компилятор еспешек под мипсы.
bump to 2023.10.5
осн. пакет "homeassistant" обрезан до мин. зависимостей.
добавлено нес-ко метапакетов (без привязки к осн. пакету "homeassistant"):
~ # opkg list | grep ha-comp
ha-component-backup - 2023.10.5-1 - Backup
ha-component-debugpy - 2023.10.5-1 - Remote Python Debugger
ha-component-dlna-dmr - 2023.10.5-1 - DLNA Digital Media Renderer
ha-component-dnsip - 2023.10.5-1 - DNS IP
ha-component-emulated-kasa - 2023.10.5-1 - Emulated Kasa
ha-component-esphome - 2023.10.5-1 - ESPHome
ha-component-ffmpeg - 2023.10.5-1 - FFmpeg
ha-component-folder-watcher - 2023.10.5-1 - Folder Watcher
ha-component-google-translate - 2023.10.5-1 - Google Translate text-to-speech
ha-component-homekit - 2023.10.5-1 - HomeKit Bridge
ha-component-homekit-controller - 2023.10.5-1 - HomeKit Device
ha-component-keenetic-ndms2 - 2023.10.5-1 - Keenetic NDMS2 Router
ha-component-media-extractor - 2023.10.5-1 - Media Extractor
ha-component-met - 2023.10.5-1 - Meteorologisk institutt (Met.no)
ha-component-norway-air - 2023.10.5-1 - Om Luftkvalitet i Norge (Norway Air)
ha-component-otp - 2023.10.5-1 - One-Time Password (OTP)
ha-component-ping - 2023.10.5-1 - Ping (ICMP)
ha-component-profiler - 2023.10.5-1 - Profiler
ha-component-python-script - 2023.10.5-1 - Python Scripts
ha-component-radio-browser - 2023.10.5-1 - Radio Browser
ha-component-season - 2023.10.5-1 - Season
ha-component-sense - 2023.10.5-1 - Sense
ha-component-shelly - 2023.10.5-1 - Shelly
ha-component-upnp - 2023.10.5-1 - UPnP/IGD
ha-component-utility-meter - 2023.10.5-1 - Utility Meter
ha-component-version - 2023.10.5-1 - Version
ha-component-voip - 2023.10.5-1 - Voice over IP
ha-component-workday - 2023.10.5-1 - Workday
ha-component-zha - 2023.10.5-1 - Zigbee Home Automation
  • 2 weeks later...
Привет всем
Подскажите плиз почему у меня не инсталлируется на KN-1011?
~ # opkg update
~ # opkg install homeassistant
Unknown package 'homeassistant'.
Collected errors:
Спасибо
В 15.11.2023 в 15:39, deamon_ttt сказал:
~ # opkg update
не читали/забыли
opkg update
  • 2 weeks later...
  • 3 weeks later...
Добрый день, добавил в configuration.yaml сервис для перезагрузки роутера
Служба работает, вручную в вкладки Службы запускается и роутер перезагружается
Также добавил скрипт для запуска этого сервиса
Но он почему то не появляется на вкладке Скрипты, хотя в файлике scripts.yaml содержимое есть. Не подскажите в чем может быть проблема?
Edited by Илья Ганжин
Добрый вечер!
Как я понимаю, у нас версия Core, то есть раздел Add-ons недоступен.
А есть у кого-то инструкция, как на Entware поставить zigbee2mqtt ?
Встроенной zha явно недостаточно для работы с Zigbee устройствами
7 часов назад, VitalyS сказал:
Добрый вечер!
https://forum.keenetic.ru/topic/10684-zigbee2mqtt-z2m/
Версия 2023.12.3 , ошибка
Logger: homeassistant.util.package
Source: util/package.py:56
First occurred: 13:01:40 (1 occurrences)
Last logged: 13:01:40
Installed version for bluetooth-data-tools resolved to None
хотя библиотека установлена
Package python3-bluetooth-data-tools (1.15.0-1) installed in root is up to date.
Подскажите пожалуйста что не так
Разобрался...  В файле opkg.conf  ссылка  src/gz ha http://bin.entware.net/mipselsf-k3.4/test/HA
повторяется  Команду
вызывал повторно после установки
Edited by Serg2103
Аналогичная проблема.
По логам ha видно идет процесс установки библиотек и так с каждым перезапуском :
2023-12-28 15:20:28.812 ERROR (SyncWorker_1) [homeassistant.util.package] Installed version for aiodiscover resolved to None
2023-12-28 15:21:41.705 ERROR (SyncWorker_7) [homeassistant.util.package] Installed version for hass-nabucasa resolved to None
2023-12-28 15:22:58.883 ERROR (SyncWorker_4) [homeassistant.util.package] Installed version for bluetooth-adapters resolved to None
2023-12-28 15:24:07.006 ERROR (SyncWorker_4) [homeassistant.util.package] Installed version for bluetooth-data-tools resolved to None
2023-12-28 15:25:12.830 ERROR (SyncWorker_4) [homeassistant.util.package] Installed version for dbus-fast resolved to None
2023-12-28 15:26:28.228 ERROR (SyncWorker_6) [homeassistant.util.package] Installed version for zeroconf resolved to None
В 08.10.2022 в 21:51, SenatoR сказал:
Спасибо за обратную связь! Я поднял MariaDB и таки настроил запись в нее, создав таблицы InnoDB и включив самый небезопасный режим его работы, а также уменьшив буферы. Памяти, конечно, она жрет, но в swap совсем не ушла. Работает неделю, полет нормальный, все стало летать. Из главных плюсов: HA работает в 1 поток, при этом встроенный в него sqllite входит в этот поток, 1 ядро роутера уходит чисто под HA, но его не хватает. Сейчас MariaDB висит на своем ядре, HA на своем и за счет этого в том числе все работает быстрее.
Важно, кто захочет повторить: нужна тонкая настройка recorder в плане какие сущности не сохранять, чтобы не хранить в базе тонны мусора (никакой оперативки не хватит), а также нужны пляски с бубном, чтобы поставить нужный модуль Python для работы с MariaBD.
Подскажите, вы модуль использовали pymysql или mysqlclient? С первым завелось, хотя второй должен быть побыстрее, но собрать его пока не получилось.
Также разбирался, в итоге нашел решение.
Проблема - ставится зависимость zigpy-znp, которой в свою очередь нужен Maturin.
В логах установки Maturin:
Решение - поставить Rust компилятор и сам Maturin из бинарников, взял отсюда: http://bin.entware.net/mipselsf-k3.4/test/. Скачиваешь пакет, ставишь через opkg install.
После этого zigpy-znp и остальные зависимости устанавливаются без проблем, ZHA работает.
Тестировал все на 2023.12.4.
55 минут назад, Denis Datsko сказал:
В 01.11.2023 в 11:46, TheBB сказал:
h(ome)a(ssistant)-component-${name} напр., ha-component-zha (https://github.com/home-assistant/core/blob/dev/homeassistant/components/zha/manifest.json#L23-L34)
root@Keenetic-6065: /opt/root $ opkg info ha-component-zha
Package: ha-component-zha
Version: 2023.12.4-1
Depends: python3-bellows, python3-pyserial, python3-pyserial-asyncio, python3-pyserial-asyncio-fast, python3-universal-silabs-flasher, python3-zha-quirks, python3-zigpy, python3-zigpy-deconz, python3-zigpy-xbee, python3-zigpy-zigate, python3-zigpy-znp
Status: unknown ok not-installed
Section: utils
Architecture: mipsel-3.4
Filename: ha-component-zha_2023.12.4-1_mipsel-3.4.ipk
Description: Zigbee Home Automation
поставит зависимости для интеграции оптом, останется подключить её в морде. Или ставить каждый пакет руками...
  • Thanks 2
Всех приветствую! Не могу установить onvif, вываливается ошибка. Пакеты libxml2 and libxslt установлены. Что можно предпринять?
Приветствую!
Подскажите пожалуйста работает ли HA с Zwave и bluetooth стиками? Или может быть даже, вроде как встроенный bluetooth на новой ultra заработает?
Переодически отваливается home assistant при приближении загрузки процессора к 99%. Сам роутер работает, а HA отваливатеся. Как вариант думал, может радиатор охлаждения мощнее нужен.
Кто-нибудь делал такое?
1 час назад, Anvar Zalibekov сказал:
К радиатору это не какого отношения не имеет
возможна работа OOM KILLER - https://interface31.ru/tech_it/2022/09/linux---nachinayushhim-chto-takoe-oom-killer-i-kak-on-rabotaet.html
Но кого же убьет OOM Killer? Бытует ошибочное мнение, что самый "толстый" процесс, занимающий самое большое количество памяти, однако это не так. Хотя заблуждения живучи, и народная молва рисует OOM Killer в виде ковбоя, врывающегося в переполненный салун и открывающий беспорядочную стрельбу по посетителям, преимущественно по толстым. Почему? Да попасть, наверное, проще...
На самом деле OOM Killer использует достаточно сложный анализ и присваивает каждому процессу очки негодности (badness) и при исчерпании памяти будет убит не кто-попало, а самый негодный процесс. Очки негодности могут принимать значения от -1000 до 1000, чем выше значение, тем более высока вероятность что OOM Killer убьет процесс. Процесс с -1000 очков никогда не будет убит OOM Killer.....
т.е. он возможно просто попал под "раздачу"
В 03.01.2024 в 11:51, mezcal сказал:
`opkg install python3-lxml` ???
добрый день.
кинетик КН3810, всё установилось, при запуске мастера настройки доходим до выбора страны-Россия и всё.
далее не работает.
победили просто переоткрытием начальной страницы.. хотя, очень странно..
спс.
Edited by Nvid Pro
3 часа назад, Великий Кукурузо сказал:
Добрый день! Вижу на гите свежачок 2024.1.1 ) Можно его в фид?
Доброго! Ачипятка? Свежая версия 2024.1.2 (pypi / git). Можно, но позже... через 2-3 часа.
Reply to this topic...
