  • 2 weeks later...
В 22.04.2026 в 11:24, TheBB сказал:
сервер (https://hass.thebb.keenetic.pro/hass/homeassistant-core-py314/) снова онлайн ещё на сутки. делайте локальные копии.
 ~  $ hass --version
2026.4.4
Failed to format translation for key 'ui.panel.config.tips.join' in language...
https://github.com/home-assistant/core/issues/169121
https://github.com/home-assistant/core/issues/169163
https://github.com/home-assistant/frontend/pull/51649
Устанавливал версию HA-2026.4.4
возникли ошибки :
~ # ~ # hass -c /opt/var/lib/homeassistant --debug --verbose
/opt/bin/sh: /: Permission denied
~ # Traceback (most recent call last):
/opt/bin/sh: syntax error: unexpected word (expecting ")")
~ #   File "/opt/bin/hass", line 8, in <module>
/opt/bin/sh: syntax error: unexpected newline
~ #     sys.exit(main())
/opt/bin/sh: ~~~~^^: not found
~ #   File "/opt/lib/python3.14/site-packages/homeassistant/__main__.py", line 3
33, in main
/opt/bin/sh: File: not found
~ #   File "/opt/lib/python3.14/site-packages/homeassistant/runner.py", line 27,
 in <module>
~ #   File "/opt/lib/python3.14/site-packages/homeassistant/bootstrap.py", line
41, in <module>
~ #   File "/opt/lib/python3.14/site-packages/homeassistant/components/api/__ini
t__.py", line 17, in <module>
~ #   File "/opt/lib/python3.14/site-packages/homeassistant/components/http/__in
it__.py", line 52, in <module>
~ #   File "/opt/lib/python3.14/site-packages/homeassistant/helpers/network.py",
 line 10, in <module>
~ #   File "/opt/lib/python3.14/site-packages/hass_nabucasa/__init__.py", line 1
9, in <module>
~ #   File "/opt/lib/python3.14/site-packages/hass_nabucasa/account_api.py", lin
e 7, in <module>
~ #   File "/opt/lib/python3.14/site-packages/hass_nabucasa/api.py", line 26, in
 <module>
~ #   File "/opt/lib/python3.14/site-packages/hass_nabucasa/auth/__init__.py", l
ine 5, in <module>
~ #   File "/opt/lib/python3.14/site-packages/hass_nabucasa/auth/cognito.py", li
ne 19, in <module>
~ #   File "/opt/lib/python3.14/site-packages/hass_nabucasa/utils.py", line 15,
in <module>
~ # ModuleNotFoundError: No module named 'icmplib'
/opt/bin/sh: ModuleNotFoundError:: not found
они должны быть , или нет  ?
В 07.05.2026 в 12:41, TSJ сказал:
Нет, если не входить в систему через `exec sh`...
В 02.05.2026 в 11:26, TheBB сказал:
root@ZKUII: /opt/root # python -V
Python 3.14.5
root@ZKUII: /opt/root # hass --version
2026.5.1
  • Thanks 2
Reply to this topic...
