- 1
4.0.14 постоянное сообщение changed "link" layer state "pending" to "running" и ошибка в таблице марщрутизации профиля
Recently Browsing 0 members
vasek00
4.0.14 настроенный wireguard клиент для выхода в интернет (в нем один cloudflare warp). В настройках прописан DNS 192.168.130.101 сам роутер AdGuardHome, весь лог забит сообщениями, "Проверка активности" стоит 240 стояло 120/30 в данном подключение думаю оно по барабану какое, "ip global 65434". Есть созданный профиль с одним только данным подключением.
[I] Mar 25 10:57:15 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running". [I] Mar 25 10:57:15 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 10:57:15 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 10:57:15 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 10:57:15 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 10:57:15 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default). [I] Mar 25 10:57:15 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101. [I] Mar 25 10:57:15 ndm: Core::Syslog: last message repeated 3 times. [I] Mar 25 11:00:18 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending". [I] Mar 25 11:00:18 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0. [I] Mar 25 11:00:18 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0. [I] Mar 25 11:00:18 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted. [I] Mar 25 11:01:21 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running". [I] Mar 25 11:01:21 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 11:01:21 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 11:01:21 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 11:01:21 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 11:01:21 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default). [I] Mar 25 11:01:21 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101. [I] Mar 25 11:01:21 ndm: Core::Syslog: last message repeated 3 times. [I] Mar 25 11:04:25 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending". [I] Mar 25 11:04:25 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0. [I] Mar 25 11:04:25 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0. [I] Mar 25 11:04:25 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted. [I] Mar 25 11:05:28 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running". [I] Mar 25 11:05:28 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 11:05:28 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 11:05:28 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 11:05:28 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0. ... [I] Mar 25 08:17:45 ndm: Core::Syslog: last message repeated 3 times. [I] Mar 25 08:20:55 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending". [I] Mar 25 08:20:55 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0. [I] Mar 25 08:20:55 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0. [I] Mar 25 08:20:55 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted. [I] Mar 25 08:21:52 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running". [I] Mar 25 08:21:52 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 08:21:52 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 08:21:52 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434. [I] Mar 25 08:21:52 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0. [I] Mar 25 08:21:52 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default). [I] Mar 25 08:21:52 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101. [I] Mar 25 08:21:52 ndm: Core::Syslog: last message repeated 3 times. [I] Mar 25 08:24:21 ndm: Netfilter::Util::Conntrack: flushed 99 IPv4 connections.Вопрос это просто лишняя информация в логе или что-то с созданным профилем происходит, так как в нем только один активный интерфейс Wireguard0 и для него может быть "adding default route via Wireguard0/removing default route via Wireguard0"
И для справки IP6, хотя не где не чего для него не настраивал.
Edited by vasek008 answers to this question
