al12s Posted August 30, 2021 Posted August 30, 2021 Решил на тестовом устройстве выполнить установку с 0... все по пунктам в итоге HASS не запускается вообще. Видимо какие-то обновления вышли, а HASS нет. Quote
al12s Posted August 30, 2021 Posted August 30, 2021 (edited) echo "src/gz ha http://bin.entware.net/mipselsf-k3.4/test/HA" >> /opt/etc/opkg.conf opkg update opkg install gcc ldd make gawk sed patch diffutils coreutils-install libffi source /opt/bin/gcc_env.sh opkg install homeassistant ~ # /opt/etc/init.d/S99hass start Starting hass... done. ~ # /opt/etc/init.d/S99hass status Checking hass... dead. ~ # hass --debug -c /opt/var/lib/homeassistant Traceback (most recent call last): File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 568, in _build_master File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 886, in require File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 777, in resolve pkg_resources.ContextualVersionConflict: (requests 2.26.0 (/opt/lib/python3.9/site-packages), Requirement.parse('requests==2.25.1'), {'homeassistant'}) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/opt/bin/hass", line 33, in <module> sys.exit(load_entry_point('homeassistant==2021.8.6', 'console_scripts', 'hass')()) File "/opt/lib/python3.9/site-packages/homeassistant/__main__.py", line 280, in main File "/opt/lib/python3.9/site-packages/homeassistant/__main__.py", line 61, in get_arguments File "/opt/lib/python3.9/site-packages/homeassistant/config.py", line 18, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/auth/__init__.py", line 18, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/auth/mfa_modules/__init__.py", line 12, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/requirements.py", line 13, in <module> File "/opt/lib/python3.9/site-packages/homeassistant/util/package.py", line 13, in <module> File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3243, in <module> File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3226, in _call_aside File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3255, in _initialize_master_working_set File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 570, in _build_master File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 583, in _build_from_requirements File "/opt/lib/python3.9/site-packages/pkg_resources/__init__.py", line 772, in resolve pkg_resources.DistributionNotFound: The 'requests==2.25.1' distribution was not found and is required by homeassistant после pip install requests==2.25.1 выдает еще ошибки в версиях компонентов, устанавливал... ничего не выходит Edited August 30, 2021 by al12s Quote
OlegOs Posted August 31, 2021 Posted August 31, 2021 TheBB, спасибо за обновление, обновился удачно, полёт нормальный ! 1 Quote
TheBB Posted September 7, 2021 Posted September 7, 2021 bump to 2021.9.4 added homeassistant-cli ~ # ~ # hass-cli --version hass-cli, version 0.9.4 ~ # Скрытый текст ~ # ~ # hass-cli info BASE_URL LOCATION REQUIRES_API_PASSWORD VERSION http://ip.add.re.ss:8123 Home Assistant True 2021.9.4 ~ # ~ # hass-cli state list ENTITY DESCRIPTION STATE CHANGED person.tester tester unknown 2021-09-07T10:22:41.968862+00:00 sun.sun Sun above_horizon 2021-09-07T10:22:53.604363+00:00 zone.home Home Assistant zoning 2021-09-07T10:22:58.983330+00:00 binary_sensor.updater Updater off 2021-09-07T10:23:00.182321+00:00 weather.home_assistant Home Assistant cloudy 2021-09-07T10:23:11.473795+00:00 binary_sensor.keenetic_viva_kn_1910_online Keenetic Viva (KN-1910) Online on 2021-09-07T10:23:11.619045+00:00 device_tracker.keenetic_ultra_ii Keenetic Ultra II home 2021-09-07T10:23:12.152176+00:00 binary_sensor.keenetic_gateway_wan_status Keenetic Gateway wan status on 2021-09-07T10:23:15.127582+00:00 sensor.keenetic_gateway_b_received Keenetic Gateway B received 834071218 2021-09-07T10:42:16.287210+00:00 sensor.keenetic_gateway_b_sent Keenetic Gateway B sent 3172951906 2021-09-07T10:42:16.288883+00:00 sensor.keenetic_gateway_packets_received Keenetic Gateway packets received 15193888 2021-09-07T10:42:16.290713+00:00 sensor.keenetic_gateway_packets_sent Keenetic Gateway packets sent 18617328 2021-09-07T10:42:16.292312+00:00 sensor.keenetic_gateway_kib_s_received Keenetic Gateway KiB/s received 1.1 2021-09-07T10:42:16.294344+00:00 sensor.keenetic_gateway_kib_s_sent Keenetic Gateway KiB/s sent 1.2 2021-09-07T10:42:16.296183+00:00 sensor.keenetic_gateway_packets_s_received Keenetic Gateway packets/s received 7.9 2021-09-07T10:42:16.297981+00:00 sensor.keenetic_gateway_packets_s_sent Keenetic Gateway packets/s sent 11.5 2021-09-07T10:42:16.299938+00:00 persistent_notification.config_entry_discovery New devices discovered notifying 2021-09-07T10:25:12.719496+00:00 ~ # ~ # hass-cli device list ID NAME MODEL MANUFACTURER AREA idididididididididididididididid Forecast Forecast Met.no idididididididididididididididid Keenetic Gateway Keenetic Gateway Keenetic Ltd. idididididididididididididididid Keenetic Viva (KN-1910) Viva (KN-1910) Keenetic Ltd. idididididididididididididididid Keenetic Ultra II None None ~ # Quote
OlegOs Posted September 7, 2021 Posted September 7, 2021 TheBB, спасибо за обновление, обновился удачно, всё работает ! только hass-cli не находится Скрытый текст ~ # /opt/etc/init.d/S99hass start Starting hass... done. ~ # hass-cli --version -sh: hass-cli: not found ~ # hass-cli info -sh: hass-cli: not found ~ # hass-cli state list -sh: hass-cli: not found ~ # hass-cli device list -sh: hass-cli: not found ~ # Quote
TheBB Posted September 7, 2021 Posted September 7, 2021 ~ # opkg update Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz Updated list of available packages in /opt/var/opkg-lists/entware Downloading http://bin.entware.net/mipselsf-k3.4/keenetic/Packages.gz Updated list of available packages in /opt/var/opkg-lists/keendev Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/Packages.gz Updated list of available packages in /opt/var/opkg-lists/ha ~ # opkg info homeassistant-cli Package: homeassistant-cli Version: 0.9.4-1 Depends: libc, libssp, librt, libpthread, python3-aiohttp, python3-click-log, python3-click, python3-dateparser, python3-jinja2, python3-jsonpath-ng, python3-netdisco, python3-regex, python3-ruamel-yaml, python3-requests, python3-tabulate Status: unknown ok not-installed Section: utils Architecture: mipsel-3.4 Size: 53017 Filename: homeassistant-cli_0.9.4-1_mipsel-3.4.ipk Description: The Home Assistant Command-line interface (hass-cli) allows one to work with a local or a remote Home Assistant Core or Home Assistant (former Hass.io) instance directly from the command-line. ~ # opkg install homeassistant-cli Installing homeassistant-cli (0.9.4-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/homeassistant-cli_0.9.4-1_mipsel-3.4.ipk Installing python3-click-log (0.3.2-2) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-click-log_0.3.2-2_mipsel-3.4.ipk Installing python3-dateparser (1.0.0-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-dateparser_1.0.0-1_mipsel-3.4.ipk Installing python3-decorator (4.4.2-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-decorator_4.4.2-1_mipsel-3.4.ipk Installing python3-jsonpath-ng (1.5.2-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-jsonpath-ng_1.5.2-1_mipsel-3.4.ipk Installing python3-netdisco (2.9.0-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-netdisco_2.9.0-1_mipsel-3.4.ipk Installing python3-regex (2021.8.21-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/python3-regex_2021.8.21-1_mipsel-3.4.ipk Installing python3-tabulate (0.8.9-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/test/HA/python3-tabulate_0.8.9-1_mipsel-3.4.ipk Configuring python3-dateparser. Configuring python3-tabulate. Configuring python3-regex. Configuring python3-decorator. Configuring python3-click-log. Configuring python3-jsonpath-ng. Configuring python3-netdisco. Configuring homeassistant-cli. *** Please install homeassistant package manually *** ~ # hass-cli --version hass-cli, version 0.9.4 ~ # Quote
OlegOs Posted September 7, 2021 Posted September 7, 2021 hass-cli заработал, Интересно, кто-нибудь ставил HA+mqtt+zigbee2mqtt, вывезет ли keenetic по ресурсам? Сейчас всё настроено через ZHA, но не все параметры у zigbee девайсов доступны. Quote
al12s Posted September 8, 2021 Posted September 8, 2021 (edited) TheBB, спасибо за обновление, После обновления в логах появилась ошибка на PyTurboJPEG==1.5.2 и очень долго загружался HA. После pip3 install PyTurboJPEG==1.5.2 ошибка в логах пропала и все заработало как надо. Edited September 8, 2021 by al12s 1 Quote
TheBB Posted September 8, 2021 Posted September 8, 2021 8 минут назад, al12s сказал: После обновления в логах появилась ошибка на PyTurboJPEG==1.5.2 и очень долго загружался HA. После pip3 install PyTurboJPEG==1.5.2 ошибка в логах пропала и все заработало как надо. ~ # ~ # opkg info python3-pyturbojpeg Package: python3-pyturbojpeg Version: 1.5.2-1 Depends: libc, libssp, librt, libpthread, python3-numpy, libjpeg-turbo Status: install user installed Section: lang Architecture: mipsel-3.4 Size: 9299 Filename: python3-pyturbojpeg_1.5.2-1_mipsel-3.4.ipk Description: A Python wrapper of libjpeg-turbo for decoding and encoding JPEG image. Installed-Time: 1630940114 ~ # Quote
al12s Posted September 8, 2021 Posted September 8, 2021 (edited) при установке с "нуля" этот пакет не устанавливается. так же при установки с "нуля" после запуска в log ошибка Unable to install package python-miio==0.5.6, хотя установлен python-miio==0.5.8, с ним не работает? Edited September 8, 2021 by al12s Quote
TheBB Posted September 8, 2021 Posted September 8, 2021 Пакет "python-miio" не собирался, его нет. Надо смотреть откуда НА пытается вытянуть настройки, или с соседнего устройства (с установленным НА), или из облака... Quote
al12s Posted September 9, 2021 Posted September 9, 2021 (edited) Подскажите пожалуйста, датчик перенес с одного Xiaomi gateway 3 на другой, физически на первом Xiaomi Gateway 3 его нет, но HA в списке устройство в ячейке интеграция выводить и на первой и второй интеграции. Как отвязать его в HA от первого Xiaomi Gateway 3? Edited September 9, 2021 by al12s Quote
al12s Posted September 9, 2021 Posted September 9, 2021 Если зайти в сам датчик в настройки - зависимости, то у него стоит две интеграции, хотя физически от первого Xiaomi Gateway он отвязан, да забыл уточнить, датчик bluetooth. Quote
dancom Posted September 13, 2021 Posted September 13, 2021 В 08.09.2021 в 14:53, al12s сказал: при установке с "нуля" этот пакет не устанавливается. так же при установки с "нуля" после запуска в log ошибка Unable to install package python-miio==0.5.6, хотя установлен python-miio==0.5.8, с ним не работает? надо ставить сначала gcc. В районе 3-й -4-й страницы я уже спотыкался на эти грабли. Посмотри по моим постам. В 09.09.2021 в 10:11, al12s сказал: Если зайти в сам датчик в настройки - зависимости, то у него стоит две интеграции, хотя физически от первого Xiaomi Gateway он отвязан, да забыл уточнить, датчик bluetooth. у меня НА с большой задержкой иногда отвязывает/цепляет устройства. Попробуй в МиНоме вручную отвяжи его, если еще не сделал. Интеграция стоит XiaomiGateway3 от AlexITT Quote
umc Posted September 14, 2021 Posted September 14, 2021 Подскажите как установить HASS Configurator ? Quote
TheBB Posted September 15, 2021 Posted September 15, 2021 8 часов назад, umc сказал: Подскажите как установить HASS Configurator ? https://github.com/danielperna84/hass-configurator/wiki/Installation 1 Quote
OlegOs Posted September 15, 2021 Posted September 15, 2021 TheBB, спасибо за обновление, всё работает ! 1 Quote
Dmitriy Sovin Posted September 20, 2021 Posted September 20, 2021 Здравствуйте! Подскажите пожалуйста, как решить проблему. HA поднят на Keenetic VIVA (KN-1910) на данный момент версия HA 2021.8.8 Интеграции: Tuya (9 устройств), Xiaomi Gateway 3 (13 устройств), Yandex Smart Home. К сожалению происходит зависание HA раз в 3-4 дня, помогает только полная перезагрузка Keenetic. На данный момент установка чистая, я не производил update, upgrade, так как при регулярном обновление зависание происходило ежедневно. Я понимаю что у моей модели мало оперативной памяти, но и зависание не происходит сразу, т.е. такое ощущение что происходит какое то переполнение. Можете ли подсказать вероятную причину и решение? Спасибо! Quote
OlegOs Posted September 20, 2021 Posted September 20, 2021 9 часов назад, Dmitriy Sovin сказал: Я понимаю что у моей модели мало оперативной памяти Оперативки да, мало, а виртуальная подкачка памяти настроена? Quote
Dmitriy Sovin Posted September 20, 2021 Posted September 20, 2021 47 минут назад, Олег Осипов сказал: Оперативки да, мало, а виртуальная подкачка памяти настроена? Да, Linux Swap 512 мб имеется! Quote
alex1 Posted September 22, 2021 Posted September 22, 2021 (edited) добрый день, проблема с обновлением Xiaomi Gateway 3 с версии 1.4.0 на новее. После обновления вылетает ошибка. На версии 1.4.0 все работает прекрасно. На версии новее в логах вылетает ошибка: при этом zigbee устройства не активные. Logger: custom_components.xiaomi_gateway3.core.gateway3 Source: custom_components/xiaomi_gateway3/core/unqlite.py:113 Integration: Xiaomi Gateway 3 (documentation, issues) First occurred: 14:18:51 (1 occurrences) Last logged: 14:18:51 Can't read mesh devices Traceback (most recent call last): File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/gateway3.py", line 741, in _get_devices db = SQLite(raw) File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 87, in __init__ self.read_db_header() File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 113, in read_db_header assert self.read(16) == b'SQLite format 3\0', "Wrong file signature" AssertionError: Wrong file signature Edited September 22, 2021 by alex1 Quote
al12s Posted September 24, 2021 Posted September 24, 2021 (edited) В 22.09.2021 в 14:19, alex1 сказал: добрый день, проблема с обновлением Xiaomi Gateway 3 с версии 1.4.0 на новее. После обновления вылетает ошибка. На версии 1.4.0 все работает прекрасно. На версии новее в логах вылетает ошибка: при этом zigbee устройства не активные. Logger: custom_components.xiaomi_gateway3.core.gateway3 Source: custom_components/xiaomi_gateway3/core/unqlite.py:113 Integration: Xiaomi Gateway 3 (documentation, issues) First occurred: 14:18:51 (1 occurrences) Last logged: 14:18:51 Can't read mesh devices Traceback (most recent call last): File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/gateway3.py", line 741, in _get_devices db = SQLite(raw) File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 87, in __init__ self.read_db_header() File "/opt/var/lib/homeassistant/custom_components/xiaomi_gateway3/core/unqlite.py", line 113, in read_db_header assert self.read(16) == b'SQLite format 3\0', "Wrong file signature" AssertionError: Wrong file signature Эту проблему решил, версия самого девайса Xiaomi Gateway 3 была 1.4.6_0012 — рекомендована AlexxIT, и в этом крылась проблема, обновил до 1.5.0_0102 — рекомендована AlexxIT и все прекрасно завелось. Edited September 24, 2021 by al12s Quote
al12s Posted September 24, 2021 Posted September 24, 2021 В 08.09.2021 в 13:50, TheBB сказал: ~ # ~ # opkg info python3-pyturbojpeg Package: python3-pyturbojpeg Version: 1.5.2-1 Depends: libc, libssp, librt, libpthread, python3-numpy, libjpeg-turbo Status: install user installed Section: lang Architecture: mipsel-3.4 Size: 9299 Filename: python3-pyturbojpeg_1.5.2-1_mipsel-3.4.ipk Description: A Python wrapper of libjpeg-turbo for decoding and encoding JPEG image. Installed-Time: 1630940114 ~ # Удалил PyTurboJPEG==1.5.2, установил python3-pyturbojpeg ошибки пропали, HA заработал стабильно, но теперь в логах появились ошибки Logger: homeassistant.components.camera.img_util Source: deps/lib/python3.9/site-packages/turbojpeg.py:492 Integration: Камера (documentation, issues) First occurred: 12:41:01 (1 occurrences) Last logged: 12:41:01 Error loading libturbojpeg; Cameras may impact HomeKit performance Traceback (most recent call last): File "/opt/lib/python3.9/site-packages/homeassistant/components/camera/img_util.py", line 96, in __init__ File "/opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/turbojpeg.py", line 148, in __init__ self.__find_turbojpeg() if lib_path is None else lib_path) File "/opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/turbojpeg.py", line 492, in __find_turbojpeg raise RuntimeError( RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually. e.g. jpeg = TurboJPEG(lib_path) Quote
TheBB Posted September 25, 2021 Posted September 25, 2021 В 24.09.2021 в 14:14, al12s сказал: Удалил PyTurboJPEG==1.5.2, установил python3-pyturbojpeg ошибки пропали, HA заработал стабильно, но теперь в логах появились ошибки зачистить "хвосты" - /opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/turbojpeg.py /opt/var/lib/homeassistant/deps/lib/python3.9/site-packages/PyTurboJPEG-* 1 Quote
umc Posted September 27, 2021 Posted September 27, 2021 В 15.09.2021 в 09:55, TheBB сказал: https://github.com/danielperna84/hass-configurator/wiki/Installation по данной ссылке установил hass-configurator таким способом pip install hass-configurator .... как теперь сделать чтоб он запускался автоматически после включения роутера? Quote
