Разметка MTD (storage) KN-1011
vasek00
KN1011
[I] Jan 1 00:00:03 kernel: mtd: creating 17 MTD partitions on "MT7621-NAND": [I] Jan 1 00:00:03 kernel: 0x000000000000-0x000000080000 : "U-Boot" [I] Jan 1 00:00:03 kernel: 0x000000080000-0x000000100000 : "U-Config" [I] Jan 1 00:00:03 kernel: 0x000000100000-0x000000180000 : "RF-EEPROM" [I] Jan 1 00:00:03 kernel: 0x000000180000-0x000000340000 : "Kernel_1" [I] Jan 1 00:00:03 kernel: 0x000000340000-0x000002bc0000 : "RootFS_1" [I] Jan 1 00:00:03 kernel: mtd: device 4 (RootFS_1) set to be root filesystem [I] Jan 1 00:00:03 kernel: 0x000000180000-0x000002bc0000 : "Firmware_1" [I] Jan 1 00:00:03 kernel: 0x000002bc0000-0x000002dc0000 : "Config_1" [I] Jan 1 00:00:03 kernel: 0x000002dc0000-0x000002fc0000 : "Storage_Legacy" [I] Jan 1 00:00:03 kernel: 0x000002fc0000-0x000003000000 : "Dump" [I] Jan 1 00:00:03 kernel: 0x000003000000-0x000003fc0000 : "Storage_A" [I] Jan 1 00:00:03 kernel: 0x000003fc0000-0x000004040000 : "U-State" [I] Jan 1 00:00:03 kernel: 0x000004040000-0x0000040c0000 : "U-Config_res" [I] Jan 1 00:00:03 kernel: 0x0000040c0000-0x000004140000 : "RF-EEPROM_res" [I] Jan 1 00:00:03 kernel: 0x000004140000-0x000006b80000 : "Firmware_2" [I] Jan 1 00:00:03 kernel: 0x000006b80000-0x000006d80000 : "Config_2" [I] Jan 1 00:00:03 kernel: 0x000006d80000-0x000007f80000 : "Storage_B" [I] Jan 1 00:00:03 kernel: 0x000000000000-0x000007f80000 : "Full" [I] Jan 1 00:00:07 kernel: Searching for suitable storage partitions... [I] Jan 1 00:00:07 kernel: Found 1st storage partition of size 16515072 bytes [I] Jan 1 00:00:07 kernel: Found 2nd storage partition of size 18874368 bytes [I] Jan 1 00:00:07 kernel: Registering UBI data partitions parser [W] Jan 1 00:00:07 kernel: Concatenating MTD devices: [W] Jan 1 00:00:07 kernel: (0): "Storage_A" [W] Jan 1 00:00:07 kernel: (1): "Storage_B" [W] Jan 1 00:00:07 kernel: into device "NDM combined UBI partition" [I] Jan 1 00:00:07 kernel: 1 ndmubipart partitions found on MTD device NDM combined UBI partition [I] Jan 1 00:00:07 kernel: mtd: creating 1 MTD partitions on "NDM combined UBI partition": [I] Jan 1 00:00:07 kernel: 0x000000000000-0x0000021c0000 : "Storage" [I] Jan 1 00:00:07 kernel: Merging storage partitions OK [W] Jan 1 03:00:11 kernel: ubi0: attaching mtd17 [W] Jan 1 03:00:11 kernel: ubi0: scanning is finished [W] Jan 1 03:00:11 kernel: ubi0: attached mtd17 (name "Storage", size 33 MiB) [W] Jan 1 03:00:11 kernel: ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [W] Jan 1 03:00:11 kernel: ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [W] Jan 1 03:00:11 kernel: ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [W] Jan 1 03:00:11 kernel: ubi0: good PEBs: 270, bad PEBs: 0, corrupted PEBs: 0 [W] Jan 1 03:00:11 kernel: ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128 [W] Jan 1 03:00:11 kernel: ubi0: max/mean erase counter: 2/1, WL threshold: 2048, image sequence number: 4028866988 [W] Jan 1 03:00:11 kernel: ubi0: available PEBs: 0, total reserved PEBs: 270, PEBs reserved for bad PEB handling: 7 [W] Jan 1 03:00:11 kernel: ubi0: background thread "ubi_bgt0d" started, PID 549 [W] Jan 1 03:00:11 kernel: UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 551 [W] Jan 1 03:00:11 kernel: UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "storage" [W] Jan 1 03:00:11 kernel: UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [W] Jan 1 03:00:11 kernel: UBIFS (ubi0:0): FS size: 31617024 bytes (30 MiB, 249 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs) [W] Jan 1 03:00:11 kernel: UBIFS (ubi0:0): reserved for root: 1493350 bytes (1458 KiB) [W] Jan 1 03:00:11 kernel: UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 10........04, small LPT model
Или KN1810
[I] Jan 1 00:00:04 kernel: mtd: creating 17 MTD partitions on "MT7621-NAND": [I] Jan 1 00:00:04 kernel: 0x000000000000-0x000000080000 : "U-Boot" [I] Jan 1 00:00:04 kernel: 0x000000080000-0x000000100000 : "U-Config" [I] Jan 1 00:00:04 kernel: 0x000000100000-0x000000180000 : "RF-EEPROM" [I] Jan 1 00:00:04 kernel: 0x000000180000-0x000000360000 : "Kernel_1" [I] Jan 1 00:00:04 kernel: 0x000000360000-0x000001d40000 : "RootFS_1" [I] Jan 1 00:00:04 kernel: mtd: device 4 (RootFS_1) set to be root filesystem [I] Jan 1 00:00:04 kernel: 0x000000180000-0x000001d40000 : "Firmware_1" [I] Jan 1 00:00:04 kernel: 0x000001d40000-0x000001dc0000 : "Config_1" [I] Jan 1 00:00:04 kernel: 0x000001dc0000-0x000001fc0000 : "Storage_Legacy" [I] Jan 1 00:00:04 kernel: 0x000001fc0000-0x000002000000 : "Dump" [I] Jan 1 00:00:04 kernel: 0x000002000000-0x000003fc0000 : "Storage_A" [I] Jan 1 00:00:04 kernel: 0x000003fc0000-0x000004040000 : "U-State" [I] Jan 1 00:00:04 kernel: 0x000004040000-0x0000040c0000 : "U-Config_res" [I] Jan 1 00:00:04 kernel: 0x0000040c0000-0x000004140000 : "RF-EEPROM_res" [I] Jan 1 00:00:04 kernel: 0x000004140000-0x000005d00000 : "Firmware_2" [I] Jan 1 00:00:04 kernel: 0x000005d00000-0x000005d80000 : "Config_2" [I] Jan 1 00:00:04 kernel: 0x000005d80000-0x000007f80000 : "Storage_B" [I] Jan 1 00:00:04 kernel: 0x000000000000-0x000007f80000 : "Full" [I] Jan 1 00:00:07 kernel: Searching for suitable storage partitions... [I] Jan 1 00:00:07 kernel: Found 1st storage partition of size 33292288 bytes [I] Jan 1 00:00:07 kernel: Found 2nd storage partition of size 35651584 bytes [I] Jan 1 00:00:07 kernel: Registering UBI data partitions parser [W] Jan 1 00:00:07 kernel: Concatenating MTD devices: [W] Jan 1 00:00:07 kernel: (0): "Storage_A" [W] Jan 1 00:00:07 kernel: (1): "Storage_B" [W] Jan 1 00:00:07 kernel: into device "NDM combined UBI partition" [I] Jan 1 00:00:07 kernel: 1 ndmubipart partitions found on MTD device NDM combined UBI partition [I] Jan 1 00:00:07 kernel: mtd: creating 1 MTD partitions on "NDM combined UBI partition": [I] Jan 1 00:00:07 kernel: 0x000000000000-0x0000041c0000 : "Storage" [I] Jan 1 00:00:07 kernel: Merging storage partitions OK [W] Jan 1 03:00:11 kernel: ubi0: attaching mtd17 [W] Jan 1 03:00:12 kernel: ubi0: scanning is finished [W] Jan 1 03:00:12 kernel: ubi0: attached mtd17 (name "Storage", size 65 MiB) [W] Jan 1 03:00:12 kernel: ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [W] Jan 1 03:00:12 kernel: ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [W] Jan 1 03:00:12 kernel: ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [W] Jan 1 03:00:12 kernel: ubi0: good PEBs: 525, bad PEBs: 1, corrupted PEBs: 0 [W] Jan 1 03:00:12 kernel: ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128 [W] Jan 1 03:00:12 kernel: ubi0: max/mean erase counter: 2/1, WL threshold: 2048, image sequence number: 876655129 [W] Jan 1 03:00:12 kernel: ubi0: available PEBs: 0, total reserved PEBs: 525, PEBs reserved for bad PEB handling: 12 [W] Jan 1 03:00:12 kernel: ubi0: background thread "ubi_bgt0d" started, PID 545 [W] Jan 1 03:00:12 kernel: UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 547 [W] Jan 1 03:00:12 kernel: UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "storage" [W] Jan 1 03:00:12 kernel: UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [W] Jan 1 03:00:12 kernel: UBIFS (ubi0:0): FS size: 63361024 bytes (60 MiB, 499 LEBs), journal size 3174400 bytes (3 MiB, 25 LEBs) [W] Jan 1 03:00:12 kernel: UBIFS (ubi0:0): reserved for root: 2992697 bytes (2922 KiB) [W] Jan 1 03:00:12 kernel: UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 5A.....59, small LPT model
Вопрос для данной модели роутера KN1011 так и останется размер storage = 33Mib а в реале
/dev/ubi0_0 27868 24 26388 0% /storage
1 ответ на этот вопрос
