Добрый день
Keenetic II  2.16.D.9.0-1
К роутеру по USB подключен бокс на два диска и одна флэшка, на которой OPKG packages
Роутер самопроизвольно 2 раза в день через день (по наюлюдению за логом за 4 дня) делает следующие действия (лог ниже)
В чем причина, как это убрать? Просто не вижу смысла в том, чтобы он будил диски - зачем лишний износ и потребление энергии?
Спасибо
[I] Feb 22 18:30:30 kernel: usb 1-1: USB disconnect, device number 4
[I] Feb 22 18:30:30 ndm: FileSystem::Repository: unregistering "0A56B5B456B5A13D:" filesystem...
[I] Feb 22 18:30:30 ndm: FileSystem::Repository: "0A56B5B456B5A13D:" filesystem unregistered.
[I] Feb 22 18:30:30 ndm: FileSystem::Repository: unregistering "B42CC4D72CC495B0:" filesystem...
[I] Feb 22 18:30:30 ndm: FileSystem::Repository: "B42CC4D72CC495B0:" filesystem unregistered.
[I] Feb 22 18:30:31 kernel: usb 1-1: new high-speed USB device number 5 using ehci-platform
[I] Feb 22 18:30:31 kernel: usb 1-1: New USB device found, idVendor=152d, idProduct=0562
[I] Feb 22 18:30:31 kernel: usb 1-1: Product: External
[I] Feb 22 18:30:31 kernel: usb 1-1: Manufacturer: JMicron
[I] Feb 22 18:30:31 kernel: scsi3 : usb-storage 1-1:1.0
[I] Feb 22 18:30:34 kernel: scsi 3:0:0:0: Direct-Access     JMicron  Tech             8136 PQ: 0 ANSI: 6
[I] Feb 22 18:30:34 kernel: sd 3:0:0:0: Attached scsi generic sg0 type 0
[I] Feb 22 18:30:34 kernel: scsi 3:0:0:1: Direct-Access     JMicron  Tech             8136 PQ: 0 ANSI: 6
[I] Feb 22 18:30:34 kernel: sd 3:0:0:1: Attached scsi generic sg1 type 0
[W] Feb 22 18:30:34 kernel: sd 3:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[W] Feb 22 18:30:34 kernel: sd 3:0:0:1: [sdb] Very big device. Trying to use READ CAPACITY(16).
[I] Feb 22 18:30:34 kernel: sd 3:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
[I] Feb 22 18:30:34 kernel: sd 3:0:0:1: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
[I] Feb 22 18:30:34 kernel: sd 3:0:0:0: [sda] Write Protect is off
[I] Feb 22 18:30:34 kernel: sd 3:0:0:0: [sda] Mode Sense: 47 00 10 08
[I] Feb 22 18:30:34 kernel: sd 3:0:0:1: [sdb] Write Protect is off
[I] Feb 22 18:30:34 kernel: sd 3:0:0:1: [sdb] Mode Sense: 47 00 10 08
[I] Feb 22 18:30:34 kernel: sd 3:0:0:0: [sda] No Caching mode page found
[I] Feb 22 18:30:34 kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
[I] Feb 22 18:30:34 kernel: sd 3:0:0:1: [sdb] No Caching mode page found
[I] Feb 22 18:30:34 kernel: sd 3:0:0:1: [sdb] Assuming drive cache: write through
[W] Feb 22 18:30:41 kernel: sd 3:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[I] Feb 22 18:30:41 kernel: sd 3:0:0:0: [sda] No Caching mode page found
[I] Feb 22 18:30:41 kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
[I] Feb 22 18:30:41 kernel:  sdb: sdb1 sdb2
[W] Feb 22 18:30:43 kernel: sd 3:0:0:1: [sdb] Very big device. Trying to use READ CAPACITY(16).
[I] Feb 22 18:30:43 kernel: sd 3:0:0:1: [sdb] No Caching mode page found
[I] Feb 22 18:30:43 kernel: sd 3:0:0:1: [sdb] Assuming drive cache: write through
[I] Feb 22 18:30:43 kernel: sd 3:0:0:1: [sdb] Attached SCSI disk
[W] Feb 22 18:30:43 ndm: FileSystem::Ext: "/dev/sdb" has an unknown partition type, ignored.
[I] Feb 22 18:30:43 kernel:  sda: sda1 sda2
[W] Feb 22 18:30:43 kernel: sd 3:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[I] Feb 22 18:30:43 kernel: sd 3:0:0:0: [sda] No Caching mode page found
[I] Feb 22 18:30:43 kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
[W] Feb 22 18:30:43 ndm: FileSystem::Ext: "/dev/sdb1" has an unknown partition type, ignored.
[I] Feb 22 18:30:43 kernel: sd 3:0:0:0: [sda] Attached SCSI disk
[I] Feb 22 18:30:43 ndm: FileSystem::Ext: ntfs "B42CC4D72CC495B0:": filesystem initialized.
[I] Feb 22 18:30:43 kernel: tntfs info (device sdb2, pid 17859): ntfs_fill_super(): fail_safe is enabled.
[I] Feb 22 18:30:43 kernel: tntfs info (device sdb2, pid 17859): load_system_files(): NTFS volume name 'disk2', version 3.1 (cluster_size 4096, PAGE_SIZE 4096).
[I] Feb 22 18:30:46 ndm: FileSystem::Repository: "B42CC4D72CC495B0:" registered.
[W] Feb 22 18:30:46 ndm: FileSystem::Ext: "/dev/sda" has an unknown partition type, ignored.
[W] Feb 22 18:30:46 ndm: FileSystem::Ext: "/dev/sda1" has an unknown partition type, ignored.
[I] Feb 22 18:30:46 ndm: FileSystem::Ext: ntfs "0A56B5B456B5A13D:": filesystem initialized.
[I] Feb 22 18:30:46 kernel: tntfs info (device sda2, pid 17859): ntfs_fill_super(): fail_safe is enabled.
[I] Feb 22 18:30:46 kernel: tntfs info (device sda2, pid 17859): load_system_files(): NTFS volume name 'disk1', version 3.1 (cluster_size 4096, PAGE_SIZE 4096).
[I] Feb 22 18:30:49 ndm: FileSystem::Repository: "0A56B5B456B5A13D:" registered.
Изменено пользователем Lexa Mad
Крайне странное поведение. В наличии два носителя, flash&hdd и оба "спят мёртвым сном", если не обращаюсь к ним принудительно. Возможно в вашем случае, есть внешние раздражители, читайте сервисы. Всякие там торренты, либо какой-то демон из entware...
