Спасибо. Пошло дальше. Теперь ошибка про pytz
~ # hass -c /opt/var/lib/homeassistant --debug --verbose
  File "/opt/bin/hass", line 8, in <module>
    sys.exit(main())
  File "/opt/lib/python3.13/site-packages/homeassistant/__main__.py", line 337, in main
  File "/opt/lib/python3.13/site-packages/homeassistant/runner.py", line 16, in <module>
  File "/opt/lib/python3.13/site-packages/homeassistant/bootstrap.py", line 41, in <module>
  File "/opt/lib/python3.13/site-packages/homeassistant/components/api/__init__.py", line 17, in <module>
  File "/opt/lib/python3.13/site-packages/homeassistant/components/http/__init__.py", line 54, in <module>
  File "/opt/lib/python3.13/site-packages/homeassistant/helpers/network.py", line 10, in <module>
  File "/opt/lib/python3.13/site-packages/hass_nabucasa/__init__.py", line 37, in <module>
  File "/opt/lib/python3.13/site-packages/hass_nabucasa/remote.py", line 22, in <module>
  File "/opt/lib/python3.13/site-packages/hass_nabucasa/acme.py", line 13, in <module>
  File "/opt/lib/python3.13/site-packages/acme/client.py", line 31, in <module>
  File "/opt/lib/python3.13/site-packages/acme/messages.py", line 21, in <module>
  File "/opt/lib/python3.13/site-packages/acme/fields.py", line 7, in <module>
  File "/opt/lib/python3.13/site-packages/pyrfc3339/__init__.py", line 17, in <module>
  File "/opt/lib/python3.13/site-packages/pyrfc3339/generator.py", line 1, in <module>
ModuleNotFoundError: No module named 'pytz'
В архиве лежит python3-pytz_2024.2_3.13-1_mipsel-3.4.ipk , но устанавливается http://bin.entware.net/mipselsf-k3.4/python3-pytz_2025.2-1_mipsel-3.4.ipk. Попробовал по аналогии поставить из архива, но установился все равно 2025.2-1 из entware
~ # opkg remove python3-pytz --autoremove --force-depends
Removing package python3-pytz from root...
~ # opkg info  python3-pytz
Package: python3-pytz
Version: 2025.2-1
Depends: libc, libssp, librt, libpthread, python3-light
Status: unknown ok not-installed
Section: lang
Architecture: mipsel-3.4
Filename: python3-pytz_2025.2-1_mipsel-3.4.ipk
Description: World timezone definitions, modern and historical
Version: 2024.2_3.13-1
Section: lang
Filename: python3-pytz_2024.2_3.13-1_mipsel-3.4.ipk
~ # opkg install /opt/HAX/python3-pytz_2024.2_3.13-1_mipsel-3.4.ipk --force-downgrade
Installing python3-pytz (2025.2-1) to root...
Downloading http://bin.entware.net/mipselsf-k3.4/python3-pytz_2025.2-1_mipsel-3.4.ipk
Configuring python3-pytz.
UPD: Закомментировал в `/opt/etc/opkg.conf` путь до bin.entware.net , переставил pytz, пошло дальше.
Изменено пользователем Greg6542
12 часов назад, Greg6542 сказал:
  Показать контент
    sys.exit(main())
  Показать контент
Version: 2025.2-1
Section: lang
Section: lang
Завелся HA? у меня так и не завелся нормально. на этапе создания учетной записи вырубается.
  • 2 недели спустя...
В 28.10.2025 в 15:08, TheBB сказал:
сервер (https://hass.thebb.keenetic.pro/hass/homeassistant-core-py313/) снова онлайн ещё на сутки. делайте локальные копии.
python bump to
 ~  $ python --version
Python 3.13.9
 ~  $ hass --version
2025.11.2
NB Если сервер снова будет недоступен - значит прилетел очередной "привет от электриков"...
2 часа назад, TheBB сказал:
python bump to
Python 3.13.9
 ~  $ hass --version
2025.11.2
Архив всех архитектур
Sos. Не загружается ha после того как вытащил диск HDD на котором был swap. Все на какое-то время подвисает, но в итоге загрузки не происходит. При проверке  hass -c /opt/var/lib/homeassistant --debug --verbose тоже не вижу глобальных ошибок.
Подскажите, что нужно сделать. На точно таком же кинетике  в другом месте ha работает нормально изначально без swap вообще.
18 часов назад, lotovalex сказал:
Добрый день, подскажите, как установить из этого архива - HA-2025.11.2_mipsel.tar.gz ?
entware установлен
opkg update
opkg install ca-certificates wget-ssl
opkg remove wget-nossl
скачать файл
распаковать архив
echo "src/gz ha_local file:///папка куда распаковали >> /opt/etc/opkg.conf
opkg update
opkg install gcc ldd make gawk sed patch diffutils coreutils-install libffi
opkg install python3-aiohappyeyeballs --force-reinstall
opkg install openssl
opkg install nano
opkg install libopenssl
opkg install libwebsockets-openssl
opkg install python3-pip
pip install --upgrade aiohappyeyeballs
pip install pyipp
opkg install xz tar
opkg install python3-universal-silabs-flasher
opkg install homeassistant
/opt/etc/init.d/S99hass stop --запуск через службу (демона)
hass -c /opt/var/lib/homeassistant --debug --verbose --запуск с контролем логов и ошибок
Изменено пользователем Andenur
В 29.12.2025 в 15:58, Andenur сказал:
opkg update
скачать файл
распаковать архив
opkg update
opkg install nano
pip install pyipp
opkg install xz tar
переставлял сейчас и достаточно так:
pip install pyipp
первая команда поставит все зависимости, вторая починит ошибку со сборкой.
В 30.12.2025 в 18:26, TheBB сказал:
 ~  $ hass --version
2026.1.1
commit rollback (-std=c++20)
Подскажите пожалуйста, как побороть эти ошибки
Регистратор: homeassistant.setup
Источник: setup.py:278
Зафиксировано первый раз: 18:42:14 (4 случая)
Зафиксировано последний раз: 18:42:21
Setup failed for 'cloud': Requirements for cloud not found: ['hass-nabucasa==1.7.0'].
Setup failed for 'cast': Requirements for cloud not found: ['hass-nabucasa==1.7.0'].
Setup failed for 'mobile_app': Requirements for cloud not found: ['hass-nabucasa==1.7.0'].
Setup failed for 'default_config': Could not setup dependencies: cloud, mobile_app
Источник: setup.py:255
Зафиксировано первый раз: 18:42:21 (1 случай)
Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['cloud', 'mobile_app']
Конфигурация configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
mobile_app:
cast:
cloud:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Изменено пользователем firefly
дополнение
Дядьки  прошу сильно не ругаться. Не опытный я сильно в этом.
Проблема вот в чем. К хопперу 3811 подключил ссд диск на 256 гб. Лежал буз дела. Предварительно его форматул в Ext4 и создал раздел linux swap на гигабайт из инструкции Вот тут Второй раздел назвал зачем то opkg. С энтвайром и nfqws проблем не возникло. Проблема возникла при попытке установить HA
Ввожу через телнет и разумеется ничего не ставится так как на репозитории (надеюсь правильно понял что это именно он) который бин энтвейр удалили нужный мне HA в папке тест.
opkg update
/opt/etc/init.d/S99hass start
Начал всякое читать и понял что надо скачать сначала. Скачал вот такое image.png.6806abe8c1f75117ffa810202d0e34ac.png
Но не пойму как правильно теперь указать путь к папке. Пробовал по разному делать конфиг и на ссд скидывал это в разные папки не получается хоть убей. Буду благодарен за правильную стройку командного кода.
делал так
echo "src/gz ha file://HA-2025.12.5/all/Packages.gz >> /opt/etc/opkg.conf
opkg update
Не получается. Так то понимаю что просто чтото делаю не так. С сервера от TheBB к сожалению не успел ничего скачать.
Помогите - направьте на путь истинный!!!
  • 3 недели спустя...
В 14.01.2026 в 14:36, TheBB сказал:
 ~  $ hass --version
2026.1.3
PS
Сами откатили - Revert back to microVAD #160821
47 минут назад, firefly сказал:
502 Bad Gateway
Перезапустил (сеть колбасит да диски начинают сыпаться)...
