Роутер KN-1811/1812 или любой другой с USB.
Конфигурация:
system set dev.usb.allow_uas 1
В любой из портов подключен:
dmesg
xhci-mtk 1a0c0000.usb: xHCI Host Controller
xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.09
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: xHCI Host Controller
usb usb2: Manufacturer: Linux 4.9-ndm-5 xhci-hcd
usb usb2: SerialNumber: 1a0c0000.usb
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-mtk
usb 2-1: New USB device found, idVendor=2e8a, idProduct=0030, bcdDevice=11.00
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: USB Flash Drive
usb 2-1: Manufacturer: Raspberry Pi
usb 2-1: SerialNumber: <edited>
usb 2-1: UAS is whitelisted for this device
scsi host0: uas
scsi 0:0:0:0: Direct-Access     General  USB Flash Drive  1100 PQ: 0 ANSI: 6
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 501350400 512-byte logical blocks: (257 GB/239 GiB)
hw_nat: MediaTek HW NAT module v5.0.7.0-22 loaded, FoE size: 16384, AG pairs: 31
usb 1-1: new high-speed USB device number 3 using xhci-mtk
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
 sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI disk
fastvpn: sizeof(bind) = 304
Через OPKG пробуем запросить smart, первый вызов отрабатывает, на следующий раз - роутер зависает и не доступен пока не отвалится накопитель:
smartctl -d sat,12 -a /dev/sda
dmesg
xhci-mtk 1a0c0000.usb: ERROR Transfer event for disabled endpoint or incorrect stream ring
xhci-mtk 1a0c0000.usb: @0000000057609f20 57d08100 00000000 1b000000 01058000
sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: IN
sd 0:0:0:0: [sda] tag#0 CDB: opcode=0xa1 a1 08 0e 00 01 00 00 00 00 ec 00 00
scsi host0: uas_eh_bus_reset_handler start
usb 2-1: reset SuperSpeed Gen 1 USB device number 2 using xhci-mtk
scsi host0: uas_eh_bus_reset_handler success
xhci-mtk 1a0c0000.usb: @00000000576093e0 57d08100 00000000 1b000000 01058001
https://support.thepihut.com/hc/en-us/articles/33860320299421-SMART-not-working-on-Raspberry-Pi-USB-Flash-Drive
Хотелось бы полноценной поддержки для накопителя, где заявлено:
  • USB 3.0 gen 1×1 interface with type-A connector
  • USB Attached SCSI Protocol with fallback to USB Mass Storage
  • USB 3.0 U1/U2 idle power saving support
  • SMART drive health reporting
Спасибо.
P.S. Отключение dev.usb.allow_uas решает проблему, но только вот Pi OS не "падает" (зависает и не обрабатывает трафик/не открывается интерфейс) от этого накопителя в любом режиме, как и любой другой линукс, например,  на Radxa E52.
Изменено пользователем Namenloss
Ответов пока нет
