Основной роутер: Hopper DSL (KN-3610)
Ретранслятор: Viva (KN-1913) связан с основным роутером по WiFi
Проблема наблюдается с устройствами умного дома - розетки, выключатели. При подключении устройства к основному роутеру - все работает как и должно. При подключении же к ретранслятору ( в списке клиентов запрещаю подключение к основному узлу) - регулярные отвалы от сети, в логах обоих роутеров это событие выглядит следующим образом:
192.168.1.51 Feb 19 20:59:33 Keenetic_Viva user info ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(c4:82:e1:82:f6:20) had deauthenticated by STA (reason: STA is leaving or has left BSS).
192.168.1.51 Feb 19 20:59:33 Keenetic_Viva user info ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(c4:82:e1:82:f6:20) had associated.
192.168.1.51 Feb 19 20:59:33 Keenetic_Viva user info ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(c4:82:e1:82:f6:20) set key done in WPA2/WPA2PSK.
192.168.1.1 Feb 19 20:59:33 SourHome user info ndhcps DHCPDISCOVER received from c4:82:e1:82:f6:20.
192.168.1.1 Feb 19 20:59:33 SourHome user info ndhcps making OFFER of 192.168.1.33 to c4:82:e1:82:f6:20.
192.168.1.1 Feb 19 20:59:33 SourHome user info ndhcps DHCPREQUEST received (STATE_SELECTING) for 192.168.1.33 from c4:82:e1:82:f6:20.
192.168.1.1 Feb 19 20:59:33 SourHome user info ndhcps sending ACK of 192.168.1.33 to c4:82:e1:82:f6:20.
192.168.1.51 Feb 19 21:37:38 Keenetic_Viva user info ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(c4:82:e1:82:f6:20) had deauthenticated by STA (reason: STA is leaving or has left BSS).
192.168.1.51 Feb 19 21:38:12 Keenetic_Viva user info ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(c4:82:e1:82:f6:20) had associated.
192.168.1.51 Feb 19 21:38:12 Keenetic_Viva user info ndm Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(c4:82:e1:82:f6:20) set key done in WPA2/WPA2PSK.
192.168.1.1 Feb 19 21:38:11 SourHome user info ndhcps DHCPDISCOVER received from c4:82:e1:82:f6:20.
192.168.1.1 Feb 19 21:38:11 SourHome user info ndhcps making OFFER of 192.168.1.33 to c4:82:e1:82:f6:20.
192.168.1.1 Feb 19 21:38:11 SourHome user info ndhcps DHCPREQUEST received (STATE_SELECTING) for 192.168.1.33 from c4:82:e1:82:f6:20.
192.168.1.1 Feb 19 21:38:12 SourHome user info ndhcps sending ACK of 192.168.1.33 to c4:82:e1:82:f6:20.
То есть проблема, судя по всему, не в настройках wifi (иначе бы не работало и с основным роутером), а именно в работе с ретранслятором. Хотя как я понимаю у основного роутера и у ретранслятора настройки сети дублируются.
Защита сети - wpa2. Пробовал отключать роуминг и band steering - ситуацию их отключение не меняет.
Может кто то сталкивался с подобным? По форуму поискал, из рекомендаций нашел только отключить ipv6, но он и так не включен. В поддержку тоже писал, но пока так и не получил ответ к сожалению.
Edited by Mordevolt
2 answers to this question
4 часа назад, Mordevolt сказал:
это основная причина. Не очень умные устройства будут до последнего долбится туда, куда считают нужным.
Достаточно просто уменьшить мощность на обоих ТД, для того чтобы клиенты более охотно выбирали то устройство что находится ближе
Тоже думал об этом, но это явно не является причиной проблемы. Такое поведение наблюдается если переместить розетку в комнату где сигнал основного роутера не добивает. И наоборот, если переместить это же устройство где сигнал обоих устройства достаточен, и разрешить подключение только к основному роутеру - дисконнектов не наблюдается.
Выглядит что проблема все таки именно в ретрансляторе, а не в уровне сигнала.
