Samsung TV DU8000UXRU "хитрое" подключение к Wifi.
vasek00
Samsung TV DU8000UXRU "хитрое" подключение к Wifi. Хитрость в том что :
1. 2.4 подключается без проблем
[W] Nov 24 14:37:01 kernel: HT Operating Mode : 2 [W] Nov 24 14:37:01 kernel: B8:хх:хх:хх:хх:80 20001 8 0 0 0 0 1 3 -45/-45/-42/-50 VHT/HTMIX 20M/20M 2S-M8/14 0/1 0/0 600 156/130 0 , 2663, 100% [W] Nov 24 14:37:01 kernel: MaxCap: HTMIX 20M 15 1 1 - 144 HTC_ICVErr:0 HTC_AAD_OM_Force:NO wdev0 [I] Nov 24 14:34:13 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(b8:хх:хх:хх:хх:80) SAE key exchange done. [I] Nov 24 14:34:13 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(b8:хх:хх:хх:хх:80) had associated. [I] Nov 24 14:34:13 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster0/AccessPoint0": STA(b8:хх:хх:хх:хх:80) set key done in WPA3/WPA3PSK. [I] Nov 24 14:34:13 ndhcps: DHCPDISCOVER received from b8:хх:хх:хх:хх:80. [I] Nov 24 14:34:13 ndhcps: making OFFER of 192.168.1.27 to b8:хх:хх:хх:хх:80. [I] Nov 24 14:34:13 ndhcps: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.27 from b8:хх:хх:хх:хх:80. [I] Nov 24 14:34:13 ndhcps: sending ACK of 192.168.1.27 to b8:хх:хх:хх:хх:80.2. 5 подключается без проблем только при WPA2 и с 1х1/80
[W] Nov 24 14:41:22 kernel: b8:хх:хх:хх:хх:80 STA 5G 5 5 8 0 1 3 -66/-58/-51/-109 VHT/VHT 80M/80M 1S-M9/1S-M9 0.8us/0.4us 0/0 598 390/433 0,9,100% [W] Nov 24 14:41:22 kernel: MaxCap: VHT 80M 2S-M9 1 1 - 867 [W] Nov 24 14:41:22 kernel: HT Operating Mode:0 HTC_ICVErr:0 HTC_AAD_OM_Force:NO wdev:8 i/btwt=0/0 Time:0000:00:23как то хитро тут с пространственными потоками, в WEB этот клиент "433 Мбит/с WPA2 и 11ac/k/v 1x1 80 МГц"
"mac": "b8:хх:хх:хх:хх:80", "ap": "WifiMaster1/AccessPoint0", "psm": false, "authenticated": true, "txrate": 433, "uptime": 1390, "txbytes": 1497355, "rxbytes": 3152672, "ht": 80, "mode": "11ac", "gi": 400, "rssi": -48, "mcs": 9, "txss": 1, "ebf": true, "dl-mu": true, "_11": [ "k", "v"При переводе 5 на WAP3 будет только
[I] Nov 24 13:05:40 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/AccessPoint0": STA(b8:хх:хх:хх:хх:80) SAE key exchange done.и далее подключения нет
На сегодня и на 43Aх - для 2.4 имеем 2х2/20 и WPA3 работает, для 5 имеем 1х1/80 и WAP2 работает хотя думаю должен 2х2/80 и для 5 с WPA3 не работает. Странность в пространственных потоках 2х2(2.4) и 1х1(5).
0 ответов на этот вопрос
