parshenkov Posted October 3, 2024 Posted October 3, 2024 Добрый день! При попытке установки entware на свой keenetic ultra получаю ошибку 147: Окт 3 09:22:55 ndm Opkg::Manager: disk is set to: OPKG:/. Окт 3 09:22:55 ndm Opkg::Manager: configured init script: "/opt/etc/init.d/rc.unslung". Окт 3 09:22:55 ndm Core::System::StartupConfig: saving (http/rci). Окт 3 09:22:55 ndm Opkg::Manager: /tmp/mnt/66FD-959A mounted to /tmp/mnt/66FD-959A. Окт 3 09:22:55 ndm Opkg::Manager: /tmp/mnt/66FD-959A mounted to /opt/. Окт 3 09:22:55 npkg inflating "aarch64-installer.tar.gz". Окт 3 09:22:55 npkg failed to inflate "aarch64-installer.tar.gz": bin/telnet: operation not permitted. Окт 3 09:22:55 ndm Opkg::Manager: system failed [0xcffd0259], exit code 147. Окт 3 09:22:55 ndm Opkg::Manager: invalid initrc "/opt/etc/init.d/rc.unslung": no such file or directory, trying /opt/etc/init.d/. Окт 3 09:22:58 ndm Core::System::StartupConfig: configuration saved. В чем может быть проблема? Quote
Denis P Posted October 3, 2024 Posted October 3, 2024 (edited) 7 часов назад, parshenkov сказал: Добрый день! При попытке установки entware на свой keenetic ultra получаю ошибку 147: Окт 3 09:22:55 ndm Opkg::Manager: disk is set to: OPKG:/. Окт 3 09:22:55 ndm Opkg::Manager: configured init script: "/opt/etc/init.d/rc.unslung". Окт 3 09:22:55 ndm Core::System::StartupConfig: saving (http/rci). Окт 3 09:22:55 ndm Opkg::Manager: /tmp/mnt/66FD-959A mounted to /tmp/mnt/66FD-959A. Окт 3 09:22:55 ndm Opkg::Manager: /tmp/mnt/66FD-959A mounted to /opt/. Окт 3 09:22:55 npkg inflating "aarch64-installer.tar.gz". Окт 3 09:22:55 npkg failed to inflate "aarch64-installer.tar.gz": bin/telnet: operation not permitted. Окт 3 09:22:55 ndm Opkg::Manager: system failed [0xcffd0259], exit code 147. Окт 3 09:22:55 ndm Opkg::Manager: invalid initrc "/opt/etc/init.d/rc.unslung": no such file or directory, trying /opt/etc/init.d/. Окт 3 09:22:58 ndm Core::System::StartupConfig: configuration saved. В чем может быть проблема? в том что вы решили установить его не на ext2/3/4, а на другую файловую систему. Edited October 3, 2024 by Denis P 1 Quote
