42A17 ошибка на Buddy 6 "WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument."
vasek00
На Buddy 6 на 42А17 c контроллером 1811 ошибка на Buddy 6 - "WifiDriverIo - invalid argument"
[E] Jul 10 14:05:58 ndhcpc: Bridge1: unable to bind to raw socket. [I] Jul 10 14:05:58 ndm: Netfilter::Ip6::Table: "filter": GigabitEthernet0/Vlan3 removed 1 rule. [I] Jul 10 14:05:58 ndm: Network::Interface::EthernetIp: "WifiMaster0/AccessPoint1": peer isolation disabled. [C] Jul 10 14:05:58 ndm: Network::Interface::Mtk::WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument. [I] Jul 10 14:05:58 ndm: Netfilter::Table: "mangle": Bridge1 removed 1 rule. [I] Jul 10 14:05:58 ndm: Netfilter::Ip6::Table: "filter": Bridge1 removed 1 rule. [C] Jul 10 14:05:58 ndm: Dhcp::Client: system failed [0xcffd06ac], unaccounted state 'undefined' for interface. [E] Jul 10 14:05:58 ndhcpc: Bridge1: socket error occurred. [I] Jul 10 14:05:58 ndhcpc: Bridge1: sending RELEASE for 192.168.15.51 to 192.168.15.101. ****** Сегмент Smart [I] Jul 10 14:05:58 ndhcpc: Bridge1: NDM DHCP client stopped (exit status 0). [I] Jul 10 14:05:58 ndm: Network::Interface::Base: "Bridge0": "dhcp-client" changed "ipv4" layer state "running" to "pending". [I] Jul 10 14:05:58 ndhcpc: Bridge0: sending RELEASE for 192.168.13.250 to 192.168.13.11. ****** Основной сегмент [W] Jul 10 14:05:58 ndm: Dhcp::Client: DHCP server is not responding. [I] Jul 10 14:05:58 ndm: Network::Interface::Ip: "Bridge0": IP address is 192.168.1.3/24. [I] Jul 10 14:05:58 ndhcpc: Bridge0: NDM DHCP client stopped (exit status 0). [I] Jul 10 14:05:58 ndm: Network::Interface::Mtk::AccessPoint: "WifiMaster0/AccessPoint0": peer isolation disabled. [C] Jul 10 14:05:58 ndm: Network::Interface::Mtk::WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument. [I] Jul 10 14:05:58 ndm: Network::Interface::Mtk::AccessPoint: "WifiMaster1/AccessPoint0": peer isolation disabled. [C] Jul 10 14:05:58 ndm: Network::Interface::Mtk::WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument. ... [I] Jul 10 14:06:04 ndm: Network::Interface::Mtk::WifiMonitor: "WifiMaster1/WifiStation0": performing site survey (flat scan). [C] Jul 10 14:06:04 ndm: Network::Interface::Mtk::WifiDriverIo: system failed [0xcffd0a10], wireless request 0x8be2: invalid argument. [C] Jul 10 14:06:04 ndm: Core::Syslog: last message repeated 2 times. [I] Jul 10 14:06:04 ndm: Network::Interface::Base: "WifiMaster1/WifiStation0": "ethernet" changed "link" layer state "running" to "pending". [I] Jul 10 14:06:04 ndm: Network::Interface::Mtk::AccessPoint: "WifiMaster0/AccessPoint1": peer isolation disabled. [I] Jul 10 14:06:05 mtkiappd: stopped. [W] Jul 10 14:06:05 ndm: Core::Server: client disconnected. [I] Jul 10 14:06:05 kernel: br0: port 3(apcli1.1) entered blocking state [I] Jul 10 14:06:05 kernel: br0: port 3(apcli1.1) entered listening state ... interface WifiMaster0 country-code RU compatibility BGN+AX channel 3 channel width 40-below power 50 rekey-interval 86400 beamforming explicit atf inbound vht downlink-mumimo uplink-mumimo downlink-ofdma uplink-ofdma spatial-reuse up ! interface WifiMaster0/AccessPoint0 rename AccessPoint description "Wi-Fi access point" mac access-list type none authentication wpa-psk ns3 *** encryption enable encryption wpa2 encryption wpa3 ip dhcp client dns-routes ssid KN wmm rrm down ************* не используется на контроллере и выключен так же тут interface WifiMaster1 country-code MY compatibility N+AC+AX channel 52 channel width 160 power 50 rekey-interval 86400 beamforming explicit atf inbound downlink-mumimo uplink-mumimo downlink-ofdma uplink-ofdma spatial-reuse whnat up ! interface WifiMaster1/AccessPoint0 rename AccessPoint_5G description "5GHz Wi-Fi access point" mac access-list type none authentication wpa-psk ns3 *** encryption enable encryption wpa2 encryption wpa3 ip dhcp client dns-routes ssid KN-5 wmm rrm ft mdid KN ft enable rssi-threshold -75 up interface GigabitEthernet0/Vlan3 ip dhcp client dns-routes up interface Bridge1 ***** есть отедльный роутер для 2.4 в котором данный сегмент основной description HomeSmart include Smart **** Wifi 2.4 и больше нечего include GigabitEthernet0/Vlan3 ***** чисто vlan ни каких LAN портовВсе работает кажется.
0 ответов на этот вопрос
