7 answers to this question
@Ацкий Падонак возможно битый файл settings.json или же он по какой-то причине не может быть загружен.
Выполните сброс settings.json в веб-интерфейсе роутера http://192.168.1.1/controlPanel/apps/torrent , после проверьте еще раз. Если ошибка сохраняется, то тогда нужен self-test файл и информация из:
more TEST:/components/transmission/settings.json
    "alt-speed-down": 50,
    "alt-speed-enabled": false,
    "alt-speed-time-begin": 540,
    "alt-speed-time-day": 127,
    "alt-speed-time-enabled": false,
    "alt-speed-time-end": 1020,
    "alt-speed-up": 50,
    "bind-address-ipv4": "0.0.0.0",
    "bind-address-ipv6": "::",
    "blocklist-enabled": false,
    "blocklist-url": "http://www.example.com/blocklist",
    "cache-size-mb": 4,
    "dht-enabled": true,
    "download-dir": "/tmp/mnt/01D6EF71724166C0/components/transmission/download",
    "download-queue-enabled": true,
    "download-queue-size": 5,
    "encryption": 0,
    "feedback-path": "/var/run/transmission-feedback",
    "idle-seeding-limit": 30,
    "idle-seeding-limit-enabled": false,
    "incomplete-dir": "/tmp/mnt/01D6EF71724166C0/components/transmission/download",
    "incomplete-dir-enabled": false,
    "lpd-enabled": false,
    "markdata": 0,
    "message-level": 2,
    "peer-congestion-algorithm": "",
    "peer-id-ttl-hours": 6,
    "peer-limit-global": 200,
    "peer-limit-per-torrent": 50,
    "peer-port": 51413,
    "peer-port-random-high": 65535,
    "peer-port-random-low": 49152,
    "peer-port-random-on-start": false,
    "peer-socket-tos": "default",
    "pex-enabled": false,
    "port-forwarding-enabled": false,
    "preallocation": 1,
    "prefetch-enabled": false,
    "queue-stalled-enabled": true,
    "queue-stalled-minutes": 30,
    "ratio-limit": 1.5000,
    "ratio-limit-enabled": false,
    "rename-partial-files": true,
    "rpc-authentication-required": true,
    "rpc-bind-address": "0.0.0.0",
    "rpc-enabled": true,
    "rpc-host-whitelist": "",
    "rpc-host-whitelist-enabled": true,
    "rpc-password": "",
    "rpc-port": 8090,
    "rpc-url": "/transmission/",
    "rpc-username": "",
    "rpc-whitelist": "*.*.*.*",
    "rpc-whitelist-enabled": true,
    "scrape-paused-torrents-enabled": true,
    "script-torrent-done-enabled": false,
    "script-torrent-done-filename": "",
    "seed-queue-enabled": false,
    "seed-queue-size": 10,
    "speed-limit-down": 15360,
    "speed-limit-down-enabled": true,
    "speed-limit-up": 15360,
    "speed-limit-up-enabled": true,
    "start-added-torrents": true,
    "trash-original-torrent-files": false,
    "umask": 18,
    "upload-slots-per-torrent": 14,
    "utp-enabled": false,
    "watch-dir": "/tmp/mnt/01D6EF71724166C0/components/transmission/watch",
    "watch-dir-enabled": true
Отключил диск и подключил другой с другой файловой системой.  Установил конфигурацию торрент в корень этого диска, всё осталось также.
было и стало
Edited by Ацкий Падонак
On 7/1/2023 at 10:25 PM, Ацкий Падонак said:
В Системном журнале  появляется  "[E] Jul  1 23:08:48 ndm: Torrent::Client: invalid RPC response.
[E] Jul  1 23:08:48 ndm: Torrent::Client: failed to get an alternative speed mode state. "
Проблема воспроизведена.
Будет взята в работу.
Спасибо!
