Обновил KN-3210 на 4.0 Alpha 12. При обращении к веб-интерфейсу в логе выходит полотно сообщений вида:
[C] Mar  8 08:33:29 ndm: Thread: "Queue::DMMYIGYYSBCIFVSJ::http/rci": lock precedence violation: CLOCK (105) after SCHEDULE (208).
[C] Mar  8 08:33:29 ndm: Thread: "Queue::DMMYIGYYSBCIFVSJ::http/rci" (536) backtrace:
[C] Mar  8 08:33:29 ndm: Thread:   Core::Server::OnNdssHostname_(Event::NdssHostname const&)+0x120
[C] Mar  8 08:33:29 ndm: Thread:   Core::System::Clock::GetTime() const+0x54
[C] Mar  8 08:33:29 ndm: Thread:   Core::Schedule::Object_::GetTime_(unsigned int&, unsigned int&, unsigned int&, unsigned int&) const+0x128
[C] Mar  8 08:33:29 ndm: Thread:   Core::Schedule::Object_::AttachTo(Xml::Node&) const+0x370
[C] Mar  8 08:33:29 ndm: Thread:   Core::Schedule::Manager::AttachScheduleTo(CString const&, Xml::Node&) const+0xd4
[C] Mar  8 08:33:29 ndm: Thread:   libndmCoreObject()+0x5b54
[C] Mar  8 08:33:29 ndm: Thread:   Core::Configurator::Execute(Command::Base const*, Command::Request const&, Command::Response&)+0x534
[C] Mar  8 08:33:29 ndm: Thread:   Core::Configurator::Serve(Command::Request const&, Command::Response&)+0x320
[C] Mar  8 08:33:29 ndm: Thread:   Core::Scgi::Auth::Run()+0x1c40
[C] Mar  8 08:33:29 ndm: Thread:   Core::Scgi::Auth::Run()+0x2bdc
[C] Mar  8 08:33:29 ndm: Thread:   Core::Scgi::Auth::Run()+0x1fec
[C] Mar  8 08:33:29 ndm: Thread:   Core::Scgi::Tools::JsonPost(Core::Configurator&, Core::Scgi::Request const&, Json::Document const&, Core::Scgi::Trace&, Json::Document&, bool*)+0x100
[C] Mar  8 08:33:29 ndm: Thread:   Core::Scgi::ThreadPool::Task_::ProcessJsonRequest_(Core::Configurator&, Core::Scgi::Request const&, Core::Scgi::Trace&, Array<char>&, Io::OStream&)+0x174
[C] Mar  8 08:33:29 ndm: Thread:   Core::Scgi::ThreadPool::Task_::Run()+0x4ec
[C] Mar  8 08:33:29 ndm: Thread:   Task::Thread::Run_()+0x3bc
[C] Mar  8 08:33:29 ndm: Thread:   Task::Thread::Run()+0x38
[C] Mar  8 08:33:29 ndm: Thread:   Thread::StartRoutine_(void*)+0x3fc
[C] Mar  8 08:33:29 ndm: Thread:   start()+0xcc
[C] Mar  8 08:33:29 ndm: Thread:   __clone()+0x6c
Вылазит как при обращении по IP, так и по доменному имени.
В 3.9.4, как и 4.0 Alpha 10, таких сообщений не замечал.
На контроллере KN-3010 с 4.0 Alpha 12 по этому поводу в логе тишина.
