Здравствуйте!
Помогите понять причины и решить проблему.
Постоянно пропадает сеть интернет.
В системном журнале следующие записи:
 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
ndm: Network::InternetChecker: Internet access detected.
Иногда затишье, иногда прям простыня из данных сообщений.
Каждый день такая ситуация. Периодичность сообщений разная и непредсказуемая.
Когда через час,когда через несколько часов.
Для примера, логи из системного журнала: за 10 января 2022.
[I] Jan 10 15:20:53 ndhcpc: GigabitEthernet0/Vlan2: received ACK for 10.123.37.94 from 10.123.32.5 lease 1200 sec.
[I] Jan 10 15:40:56 ndhcpc: Core::Syslog: last message repeated 2 times.
[I] Jan 10 15:44:46 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 15:45:22 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 15:50:57 ndhcpc: GigabitEthernet0/Vlan2: received ACK for 10.123.37.94 from 10.123.32.5 lease 1200 sec.
[I] Jan 10 15:53:27 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 15:53:42 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 15:54:07 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 15:55:53 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 36447.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: a new nat rule appended.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: redirect rule added: tcp GigabitEthernet0/Vlan2:36447 -> 192.168.1.108:36447.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: a new filter rule appended.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: forward rule added: tcp GigabitEthernet0/Vlan2 -> 192.168.1.108:36447.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: redirect and forward rules deleted: udp 36447.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: redirect rule added: udp GigabitEthernet0/Vlan2:36447 -> 192.168.1.108:36447.
[I] Jan 10 15:55:53 ndm: UPnP::Manager: forward rule added: udp GigabitEthernet0/Vlan2 -> 192.168.1.108:36447.
[I] Jan 10 15:56:22 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 15:57:07 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 15:58:02 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 16:00:57 ndhcpc: GigabitEthernet0/Vlan2: received ACK for 10.123.37.94 from 10.123.32.5 lease 1200 sec.
[I] Jan 10 16:01:48 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 16:01:54 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 16:03:18 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 16:04:33 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 16:08:33 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 16:08:38 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 16:09:18 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 16:09:18 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 16:10:59 ndhcpc: GigabitEthernet0/Vlan2: received ACK for 10.123.37.94 from 10.123.32.5 lease 1200 sec.
[I] Jan 10 18:01:00 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 18:01:11 ndhcpc: GigabitEthernet0/Vlan2: received ACK for 10.123.37.94 from 10.123.32.5 lease 1200 sec.
[I] Jan 10 18:01:17 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 18:07:12 ndm: Network::InternetChecker: Internet access lost (status: 0x0007).
[I] Jan 10 18:08:03 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 19:50:28 ndhcps: sending ACK of 192.168.1.62 to 4a:07:1b:d4:96:ad.
[I] Jan 10 19:51:22 ndhcpc: GigabitEthernet0/Vlan2: received ACK for 10.123.37.94 from 10.123.32.5 lease 1200 sec.
[I] Jan 10 19:51:25 wmond: WifiMaster0/AccessPoint0: (MT7615) STA(c8:b2:9b:f2:06:ac) had deauthenticated by STA (reason: unspecified).
[I] Jan 10 19:51:35 wmond: WifiMaster1/AccessPoint0: (MT7615) STA(c8:b2:9b:f2:06:ac) had associated successfully.
[I] Jan 10 19:51:35 wmond: WifiMaster1/AccessPoint0: (MT7615) STA(c8:b2:9b:f2:06:ac) set key done in WPA2/WPA2PSK.
[I] Jan 10 19:51:35 ndhcps: DHCPDISCOVER received from c8:b2:9b:f2:06:ac.
[I] Jan 10 19:51:35 ndhcps: making OFFER of 192.168.1.63 to c8:b2:9b:f2:06:ac.
[I] Jan 10 19:51:35 ndhcps: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.63 from c8:b2:9b:f2:06:ac.
[I] Jan 10 19:51:35 ndm: Network::InternetChecker: Internet access lost (status: 0x0003).
[I] Jan 10 19:51:35 ndhcps: sending ACK of 192.168.1.63 to c8:b2:9b:f2:06:ac.
[I] Jan 10 19:51:37 ndm: Network::InternetChecker: Internet access detected.
[I] Jan 10 19:51:51 wmond: WifiMaster1/AccessPoint0: (MT7615) STA(c8:b2:9b:f2:06:ac) had deauthenticated by STA (reason: unspecified).
Полный лог за неделю во вложении.
Что означает  status: 0x0003?
К роутеру подключено каждый день около 5 устройств по Wifi и 1-2 по LAN.
Хочу понять, или провайдер виноват в обрывах или всё же дело в роутере.
Комфортно сидеть в интернете не получается от слова совсем...
Прошу вашей помощи.
log.txt
1 час назад, loginella сказал:
easyconfig check exclude-gateway
system configuration save
После перезагрузки может помочь.
Что означает данная команда? Где её вводить?
Только что, noliker сказал:
Эта команда значит, что мы отключаем проверку шлюза по умолчанию. Вводить ее в cli, можно зайти по 192.168.1.1/a и там эти команды ввести по очереди.
Вторая команда сохраняет конфиг.
Чтобы вернуть обратно введите
no easyconfig check exclude-gateway
2 часа назад, Илья Картавенко сказал:
Какой должен быть результат? Не очень понимаю, зачем отключать проверку шлюза и потом её включать. И когда её нужно будет обратно включать?
2 минуты назад, noliker сказал:
Всё же прочтите статью по моей ссылке. Если это решение поможет, то не включать никогда, пока у Вас такой своеобразный провайдер.
16 минут назад, noliker сказал:
Когда она отключена, все должно работать как обычно, роутер не будет реагировать, на недоступность шлюза и на другие сбои логики со стороны провайдера и линии. Это нужно, что бы проверить, проблема в логике или где то глубже.
У меня была сходная проблема Я обратился в поддержку кинетика и собраная таким образом информация мне помогла при обращении в поддержку провайдера.
10 минут назад, Илья Картавенко сказал:
Не будет спамить его APR-запросами, как он любит по умолчанию делать и с домашней сетью. Понятно, что маломощным провайдерам такой спам не нравится.
1 минуту назад, loginella сказал:
Это да, я просто объясняю человеку простым языком.
Я понял. Просто
17 минут назад, Илья Картавенко сказал:
не синонимично "не будет пытаться проверить".
А реальная недоступность шлюза всё равно приведёт к обрыву связи, но уже со стороны и по вине провайдера, и маршрутизатор это зафиксирует. Так что контроль над ситуацией не теряется.
6 минут назад, loginella сказал:
Я понял. Просто
Ну при реальной недоступности шлюза среагирует любой роутер.
Когда у меня была похожая ситуация я ставил другой роутер черную Extra, так вот, там подобной функции нет и роутер не замечал проблем, как-будто все нормально.
По совету Mamay отключил торрент на ноутбуке. Вроде как интернет стал пошустрее. Но основная нагрузка на сеть будет вечером. Смогу сообщить что и как только завтра. Пока команду в cli не запускал.
А вот торрент на ноутбуке такое при достаточных мощностях провайдера не вызывает. Выше лично я говорил о торрент-клиенте на самом маршрутизаторе и о том, что его использование - зло.
Соответственно, если вечером всё будет хорошо, то два пути: при этом провайдере забыть о торрентах, или же забыть о протоколе utp в торрент-клиенте. А маршрутизатор просто положение дел показал.
9 минут назад, noliker сказал:
А кстати, что за провайдер, в каком городе?
4 часа назад, Илья Картавенко сказал:
Москва. Almatel. Бывший 2КОМ. При 2КОМ такого не было. Но и 500мбит не было.
Изменено пользователем noliker
18 минут назад, noliker сказал:
Не знаю ни того ни другого. Я из СПб.
По районам вообще беда. Всё уже поделено. Хочешь провайдера? Ок! Но его не пускают. Или говорят "места уже нет".
1 минуту назад, noliker сказал:
У нас так же примерно.
Сутки без торрента на ноутбуке. Ощущения лучше, живее намного))
В логах всё равно какая-то гадость лезет:
Тут раньше как раз был internet access lost. Сейчас его нет.
Янв 14 13:29:27 ndm
UPnP::Manager: redirect and forward rules deleted: udp 3659.
Янв 14 13:39:08 ndhcpc
Янв 14 14:29:15 ndhcpc
Core::Syslog: last message repeated 5 times.
Появились вот такие:
Янв 14 16:16:35 wmond
WifiMaster0/AccessPoint0: (MT7615) STA(8a:f6:88:df:93:0f) had been aged-out and disassociated (idle silence).
Янв 14 18:12:57 ndm
Io::UdpSocket: unable to write data: operation not permitted.
Что это за звери?
И как теперь с торрентом делать, как подружиться?
5 минут назад, noliker сказал:
  Показать содержимое
Янв 14 13:29:27 ndm
  Скрыть содержимое
Янв 14 18:12:57 ndm
Что это за звери?
Очень странно, что торрент дает такой результат.
Покажите свои настройки wifi на роутере, и покажите настройки адаптера на ноутбуке. (Это надо щелкнуть в диспетчере устройств по сетевым устройствам, а затем правой кнопкой щелкнуть на вашем wifi адаптере и выбрать свойства, а в свойствах нужно выбрать вкладку дополнительно)
Настройки на роутере и настройки адаптера заскриньте.
17 часов назад, noliker сказал:
Что это за звери?
Первое - сообщение о факте, второе - тоже ничего критичного.
Как я писал выше, оставить в клиенте только протокол ТСР, ограничить разумным значением (не более 100) число соединений на торрент, равно как общее число соединений паритетно выставить, равно как указать, что одновременно только 1 торрент может скачиваться, равно как ограничить в клиенте весь трафик, в том числе служебный, и указать ограничение на уровне 60% тарифной скорости. Иначе оборудование провайдера, весьма слабое в Вашем случае, и дальше будет от торрентов (не только ж Вы их любите) входить в невменяемое состояние и логично начинать защищаться от любителей торрентов. Приоритезации трафика у Вашего провайдера само собой нет, что лишь ухудшает и его, и абонентов ситуацию. Маршрутизатор тут ничем не проможет.
17 часов назад, Илья Картавенко сказал:
Ничего странного: до текущего (оптика и приоритезация трафика на стороне провайдера) у меня тоже был провайдер, даже довольно мощный, но без приоритезации трафика, потому торрент мог положить канал запросто. А вот сейчас, даже при актуальном маршрутизаторе, если убрать в клиенте вообще все ограничения на число соединений и скорость, и запустить несколько торрентоа, где тысячи сидов, то это вообще никому и ничему не помешает. Так что лично я через такие "странности" в своё время проходил.
