Добрый день.
Имеется Keenetic Ultra KN-1810 и провайдер Ростелеком, подключен кабелем от свича до роутера, без скруток и тд (цельный кабель до квартиры).
Версия ПО: 3.6.12(официальный релиз)
С завидной постоянностью падает соединение по вечерам, после 30-40 сек восстанавливается.
Выдержка из лога под спойлером, подскажите с чем это связано?
Окт 25 23:08:10 pppd[469]
LCP terminated by peer
Connect time 4319.9 minutes.
Sent 1695334075 bytes, received 752140008 bytes.
Modem hangup
Connection terminated.
Sent PADT
Окт 25 23:08:10 ndm
Network::Interface::Ip: "PPPoE0": IP address cleared.
Окт 25 23:08:11 ndm
Http::Nginx: loaded SSL certificate for "b776fc51897d719cc0a4433a.keenetic.io".
Окт 25 23:08:11 ndm
Core::Server: started Session /var/run/ndm.core.socket.
Окт 25 23:08:11 ndm
Core::Session: client disconnected.
Окт 25 23:08:11 pppd[469]
Exit.
Окт 25 23:08:11 ndm
Service: "PPPoE0": unexpectedly stopped.
Окт 25 23:08:11 ndm
Network::Interface::Base: "PPPoE0": interface is up.
Окт 25 23:08:11 ndm
Http::Manager: updated configuration.
Окт 25 23:08:11 ndm
Окт 25 23:08:11 ndm
Окт 25 23:08:13 pppd[7321]
Plugin rp-pppoe.so loaded.
pppd 2.4.4-4 started by root, uid 0
Found unterminated session: 621:00:90:1a:aa:47:01
Sent PADT
Окт 25 23:08:15 pppd[7321]
PPP session is 28143
Using interface ppp0
Connect: ppp0 <--> eth3
Remote message: Authentication success,Welcome!
PAP authentication succeeded
peer from calling number 00:90:1A:AA:49:08 authorized
local IP address 109.165.110.164
remote IP address 178.34.128.49
primary DNS address 80.254.108.202
secondary DNS address 80.254.108.194
Окт 25 23:08:15 ndm
Окт 25 23:08:15 ndm
Окт 25 23:08:15 ndm
Network::Interface::Ppp: "PPPoE0": interface "PPPoE0" is global, priority 33117.
Окт 25 23:08:15 ndm
Network::Interface::Ppp: "PPPoE0": adding default route via PPPoE0.
Окт 25 23:08:15 ndm
Network::Interface::Ppp: "PPPoE0": adding nameserver 80.254.108.202.
Окт 25 23:08:15 ndm
Dns::Manager: name server 80.254.108.202 added, domain (default).
Окт 25 23:08:15 ndm
Network::Interface::Ppp: "PPPoE0": adding nameserver 80.254.108.194.
Окт 25 23:08:15 ndm
Dns::Manager: name server 80.254.108.194 added, domain (default).
Окт 25 23:08:15 ndm
Network::Interface::Ip: "PPPoE0": IP address is 109.165.110.164/32.
Окт 25 23:08:15 ndm
Network::InterfaceFlusher: flushed PPPoE0 conntrack and route cache.
Окт 25 23:08:16 ndm
Окт 25 23:08:16 ndm
Окт 25 23:08:16 ndm
Окт 25 23:08:16 ndm
Окт 25 23:08:16 ndm
Окт 25 23:08:16 ndm
Окт 25 23:11:04 ndm
Core::Ndss: [7363] cannot connect to the server.
eXtrimAll07
Добрый день.
Версия ПО: 3.6.12 (официальный релиз)
Окт 25 23:08:10 pppd[469] LCP terminated by peer Окт 25 23:08:10 pppd[469] Connect time 4319.9 minutes. Окт 25 23:08:10 pppd[469] Sent 1695334075 bytes, received 752140008 bytes. Окт 25 23:08:10 pppd[469] Modem hangup Окт 25 23:08:10 pppd[469] Connection terminated. Окт 25 23:08:10 pppd[469] Sent PADT Окт 25 23:08:10 ndm Network::Interface::Ip: "PPPoE0": IP address cleared. Окт 25 23:08:11 ndm Http::Nginx: loaded SSL certificate for "b776fc51897d719cc0a4433a.keenetic.io". Окт 25 23:08:11 ndm Core::Server: started Session /var/run/ndm.core.socket. Окт 25 23:08:11 ndm Core::Session: client disconnected. Окт 25 23:08:11 pppd[469] Exit. Окт 25 23:08:11 ndm Service: "PPPoE0": unexpectedly stopped. Окт 25 23:08:11 ndm Network::Interface::Base: "PPPoE0": interface is up. Окт 25 23:08:11 ndm Http::Manager: updated configuration. Окт 25 23:08:11 ndm Core::Server: started Session /var/run/ndm.core.socket. Окт 25 23:08:11 ndm Core::Session: client disconnected. Окт 25 23:08:13 pppd[7321] Plugin rp-pppoe.so loaded. Окт 25 23:08:13 pppd[7321] pppd 2.4.4-4 started by root, uid 0 Окт 25 23:08:13 pppd[7321] Found unterminated session: 621:00:90:1a:aa:47:01 Окт 25 23:08:13 pppd[7321] Sent PADT Окт 25 23:08:15 pppd[7321] PPP session is 28143 Окт 25 23:08:15 pppd[7321] Using interface ppp0 Окт 25 23:08:15 pppd[7321] Connect: ppp0 <--> eth3 Окт 25 23:08:15 pppd[7321] Remote message: Authentication success,Welcome! Окт 25 23:08:15 pppd[7321] PAP authentication succeeded Окт 25 23:08:15 pppd[7321] peer from calling number 00:90:1A:AA:49:08 authorized Окт 25 23:08:15 pppd[7321] local IP address 109.165.110.164 Окт 25 23:08:15 pppd[7321] remote IP address 178.34.128.49 Окт 25 23:08:15 pppd[7321] primary DNS address 80.254.108.202 Окт 25 23:08:15 pppd[7321] secondary DNS address 80.254.108.194 Окт 25 23:08:15 ndm Network::Interface::Base: "PPPoE0": interface is up. Окт 25 23:08:15 ndm Network::Interface::Base: "PPPoE0": interface is up. Окт 25 23:08:15 ndm Network::Interface::Ppp: "PPPoE0": interface "PPPoE0" is global, priority 33117. Окт 25 23:08:15 ndm Network::Interface::Ppp: "PPPoE0": adding default route via PPPoE0. Окт 25 23:08:15 ndm Network::Interface::Ppp: "PPPoE0": adding nameserver 80.254.108.202. Окт 25 23:08:15 ndm Dns::Manager: name server 80.254.108.202 added, domain (default). Окт 25 23:08:15 ndm Network::Interface::Ppp: "PPPoE0": adding nameserver 80.254.108.194. Окт 25 23:08:15 ndm Dns::Manager: name server 80.254.108.194 added, domain (default). Окт 25 23:08:15 ndm Network::Interface::Ip: "PPPoE0": IP address is 109.165.110.164/32. Окт 25 23:08:15 ndm Network::InterfaceFlusher: flushed PPPoE0 conntrack and route cache. Окт 25 23:08:16 ndm Http::Nginx: loaded SSL certificate for "b776fc51897d719cc0a4433a.keenetic.io". Окт 25 23:08:16 ndm Core::Server: started Session /var/run/ndm.core.socket. Окт 25 23:08:16 ndm Core::Session: client disconnected. Окт 25 23:08:16 ndm Http::Manager: updated configuration. Окт 25 23:08:16 ndm Core::Server: started Session /var/run/ndm.core.socket. Окт 25 23:08:16 ndm Core::Session: client disconnected. Окт 25 23:11:04 ndm Core::Ndss: [7363] cannot connect to the server.3 answers to this question
