Привет! Минск на связи
Keenetic Giga KN-1010 утром резко пропал LAN - до этого 4 месяца без проблем. По всем портам. Вафля работает как часы.  Как у настоящего ламера у меня все настройки центра "По умолчанию". У провайдера айпи динамический. Что делать, как быть? Пробовал играться с ДНС - или не то делал, или не сработали манипуляции. Естественно, делал ребуты.
30 минут назад, Remarque сказал:
Для начала конф файл и раздел
interface Bridge0
    rename Home
    description "Home VLAN"
    inherit GigabitEthernet0/Vlan1
    include AccessPoint
    include AccessPoint_5G
строка inherit GigabitEthernet0/Vlan1 и есть наличие LAN портов в дом.сети. В логах или selftest найти записи по конф.Bridge0
[I] Apr 21 18:17:18 ndm: Network::Interface::Base: "Bridge0": interface is down.
[I] Apr 21 18:17:18 ndm: Network::Interface::Base: "Bridge0": network MTU reset to default.
[I] Apr 21 18:17:18 ndm: Network::Interface::Base: "Bridge0": interface is up.
[I] Apr 21 18:17:18 ndm: Network::Interface::Repository: "Bridge0" interface created.
[I] Apr 21 18:17:19 ndm: Network::Interface::Base: "Bridge0": renamed to "Home".
[I] Apr 21 18:17:19 ndm: Network::Interface::Base: "Bridge0": description saved.
[I] Apr 21 18:17:19 kernel: br0: port 1(eth2.1) entered blocking state
[I] Apr 21 18:17:19 kernel: br0: port 1(eth2.1) entered disabled state
[I] Apr 21 18:17:19 kernel: device eth2.1 entered promiscuous mode
[I] Apr 21 18:17:19 kernel: device eth2 entered promiscuous mode
[I] Apr 21 18:17:19 kernel: br0: port 1(eth2.1) entered forwarding state
[I] Apr 21 18:17:19 kernel: br0: disabled STP choke for port 1(eth2.1)
[I] Apr 21 18:17:19 ndm: Network::Interface::Base: "Bridge0": interface is up.
[I] Apr 21 18:17:19 ndm: Network::Interface::Mac: "Bridge0": backed up the default address 50:хх:хх:хх:хх:хх of "Home" before changing.
[I] Apr 21 18:17:19 ndm: Network::Interface::Ip: "Bridge0": IP address cleared.
[I] Apr 21 18:17:19 ndm: Network::Interface::Ip: "Bridge0": global priority unchanged.
[I] Apr 21 18:17:19 ndm: Network::Interface::Ip: "Bridge0": global priority cleared.
[I] Apr 21 18:17:19 ndm: Network::Interface::Bridge: "Bridge0": GigabitEthernet0/Vlan1 inherited in Bridge0.
[I] Apr 21 18:17:19 kernel: br0: port 2(ra0) entered blocking state
[I] Apr 21 18:17:19 kernel: br0: port 2(ra0) entered disabled state
[I] Apr 21 18:17:20 kernel: device ra0 entered promiscuous mode
[I] Apr 21 18:17:20 kernel: br0: disabled STP choke for port 2(ra0)
[I] Apr 21 18:17:20 kernel: br0: port 1(eth2.1) entered disabled state
[I] Apr 21 18:17:20 kernel: br0: port 1(eth2.1) entered blocking state
[I] Apr 21 18:17:20 kernel: br0: port 1(eth2.1) entered forwarding state
[I] Apr 21 18:17:20 ndm: Network::Interface::Bridge: "Bridge0": AccessPoint included.
[I] Apr 21 18:17:20 kernel: br0: port 3(rai0) entered blocking state
[I] Apr 21 18:17:20 kernel: br0: port 3(rai0) entered disabled state
[I] Apr 21 18:17:20 kernel: device rai0 entered promiscuous mode
[I] Apr 21 18:17:20 kernel: br0: disabled STP choke for port 3(rai0)
[I] Apr 21 18:17:20 ndm: Network::Interface::Bridge: "Bridge0": AccessPoint_5G included.
eth2.1 интерфейс LAN портов, в Bridge0 или он же br0 (тдт он же основной интерфейс роутера) =  wifi (2,4 и 5) и плюс LAN или
/ # brctl show
bridge name     bridge id               STP enabled     interfaces
br0             8000.50ххххххххххх      no              eth2.1
                                                        rai0
                                                        ra4.1
                                                        rai4.1
                                                        ra0
eth2.1 - LAN
raiх и rax - wifi
include AccessPoint
