2 минуты назад, AndreBA сказал:
exFAT, что то не захотел монтироваться(возможно я его не умею готовить):
  Скрыть содержимое
Май 3 17:47:14
kernel
usb 1-2: USB disconnect, device number 13
Май 3 17:47:17
kernel
usb 1-1: new high-speed USB device number 14 using xhci-hcd
Май 3 17:47:17
kernel
usb 1-1: New USB device found, idVendor=058f, idProduct=6387
Май 3 17:47:17
kernel
usb 1-1: Product: Mass Storage Device
Май 3 17:47:17
kernel
usb 1-1: Manufacturer: Generic
Май 3 17:47:17
kernel
usb 1-1: SerialNumber: 8KZZCY6K
Май 3 17:47:17
kernel
usb-storage 1-1:1.0: Quirks match for vid 058f pid 6387: 400
Май 3 17:47:17
kernel
scsi12 : usb-storage 1-1:1.0
Май 3 17:47:20
kernel
scsi 12:0:0:0: Direct-Access JetFlash TS2GJF2A/120 8.07 PQ: 0 ANSI: 2
Май 3 17:47:20
kernel
sd 12:0:0:0: Attached scsi generic sg0 type 0
Май 3 17:47:20
kernel
sd 12:0:0:0: [sda] 4014078 512-byte logical blocks: (2.05 GB/1.91 GiB)
Май 3 17:47:20
kernel
sd 12:0:0:0: [sda] Write Protect is off
Май 3 17:47:20
kernel
sd 12:0:0:0: [sda] Mode Sense: 03 00 00 00
Май 3 17:47:20
kernel
sd 12:0:0:0: [sda] No Caching mode page found
Май 3 17:47:20
kernel
sd 12:0:0:0: [sda] Assuming drive cache: write through
Май 3 17:47:20
kernel
Май 3 17:47:20
kernel
Май 3 17:47:20
kernel
sda: sda1
Май 3 17:47:20
kernel
Май 3 17:47:20
kernel
Май 3 17:47:20
kernel
sd 12:0:0:0: [sda] Attached SCSI removable disk
Май 3 17:47:20
ndm
FileSystem::Ext: "/dev/sda" has an unknown partition type, ignored.
Май 3 17:47:20
ndm
FileSystem::Volume::ExFat: found filesystem without label.
Май 3 17:47:20
ndm
FileSystem::Ext: a filesystem with the same label (NO NAME, ) already mounted.
Май 3 17:47:20
ndm
FileSystem::Repository: failed to create a new filesystem.
Форматировал флешку так:
  Скрыть содержимое
~$ sudo mkfs -t exfat /dev/sdc1
[sudo] пароль для andreba:
mkexfatfs 1.2.8
Creating... done.
Flushing... done.
File system created successfully.
Это похоже на баг, надо проверить.
Создайте ее через opkg exfat format.
30 минут назад, AndreBA сказал:
@Le ecureuilПроверку NTFS проходит:
  Показать содержимое
А вод формат нет, (может не правильно команду ввожу)
  Скрыть содержимое
(config)> opkg ntfs format baa:
formatting device "/dev/sda4" to NTFS filesystem ...
Opkg::Command::FsFormatTool error[268239063]: system failed [0xcffd00d7].
Тоже похоже на баг, нужно проверить.
5 минут назад, Le ecureuil сказал:
Отформатировалась:
(config)> no system mount BAA:
FileSystem::Repository: "BAA:" unmounted.
(config)> opkg exfat format BAA:
formatting device "/dev/sda1" to EFAT filesystem ...
failed to init locale/codeset
exfatprogs version : 1.0.2
Creating exFAT filesystem(/dev/sda1, cluster size=131072)
Writing volume boot record: done
Writing backup volume boot record: done
Fat table creation: done
Allocation bitmap creation: done
Upcase table creation: done
Writing root directory entry: done
Synchronizing...
exFAT format complete!
Подключилась:
15 минут назад, AndreBA сказал:
Компонент поддержка фаловых систем exfat установили?
Только что, r13 сказал:
Да мне и одного поста бы хватило :D
Конечно:
Так же, в ntfs не форматирует, остальное форматирует
(config)> opkg ntfs format 3fd07022-b377-41e0-8790-d5f01c9110bb:
(config)>
Проверка HDD на 2ТБ в  NTFS:
(config)> no system mount Seagate:
FileSystem::Repository: "Seagate:" unmounted.
(config)> opkg ntfs check Seagate:
checking NTFS filesystem on device "5F9198C104C1F6EC:" / "Seagate" ("/dev/sda1") ...
ntfsck 3017.7.18.4
Couldn't set local environment, using default ''.
Restart page header cannot be read
Resetting the NTFS Journal.
Syncing device ...
Checking NTFS Superblock ...
Device name        : /dev/sda1
NTFS volume version: 3.1
Cluster size       : 4096 bytes
Current volume size: 2000397791744 bytes (2000398 MB)
Checking system files ...
Current device size: 2000397795328 bytes (2000398 MB)
Checking for bad sectors ...
Checking attributes ...
Checking directory structure ...
Checking for orphaned files ...
Scanning orphaned files completed.
Checking cluster allocation ...
Checking cluster allocation bitmap ...
Checking $MFT bitmap ...
Space in use       : 248328 MB (12.4%)
Done NTFS checking and repair on device '/dev/sda1'.
Syncing device ...
10 минут назад, AndreBA сказал:
  Скрыть содержимое
ntfsck 3017.7.18.4
Syncing device ...
Syncing device ...
Сколько по времени шла?
А вот 1ТБ в NTFS проверился секунд за 15.
При первой проверке, что то профиксилось:
(config)> no system mount Samsung:
FileSystem::Repository: "Samsung:" unmounted.
(config)> opkg ntfs check Samsung:
checking NTFS filesystem on device "494D016210398DBC:" / "Samsung" ("/dev/sda1") ...
ntfsck 3017.7.18.4
The file system wasn't safely closed on Windows. Fixing.
* Syncing successful after playing 16 actions
Syncing device ...
NTFS log replay complete.
Current volume size: 1000202039808 bytes (1000203 MB)
Current device size: 1000202043392 bytes (1000203 MB)
Fixing minor inconsistency in data size for inode 8201 (0x2009)
Space in use       : 236159 MB (23.6%)
Syncing device ...
Вторая проверка тоже не более 15секунд:
ntfsck 3017.7.18.4
Syncing device ...
Syncing device ...
Диску уже более 8 лет.
@Le ecureuil Если есть в "метке" пробел, то выдает ошибку:
(config)> no system mount NO NAME:
Command::Base error[7405602]: filesystem: argument parse error.
(config)> no system mount EXT4 D4F79D:
По UUID отрабатывает:
(config)> no system mount 0AF5-C254:
FileSystem::Repository: "0AF5-C254:" unmounted.
Если "метка" без пробела, то отрабатывает корректно. Так задумано или можно исправить?
25 минут назад, AndreBA сказал:
  Скрыть содержимое
  Показать содержимое
В кавычках метку пишите и все будет ок, иначе это 2 параметра для системы
Изменено пользователем r13
3 минуты назад, r13 сказал:
Да, как то упустил это момент.
Спасибо!
(config)> no system mount "EXT4 D4F79D:"
FileSystem::Repository: "EXT4 D4F79D:" unmounted.
Вообще именно для этого и сделан uuid :) Чтобы при наличии разных юникодных символов типа emoji все равно можно было нормально обратиться к разделу.
3 часа назад, Le ecureuil сказал:
exfat у всех нормально работает?
Наверное кто сильно просил exfat не тестируют, ждут.
Я только проверил монтирование и форматирование....😬
На первый взгляд все вроде ок. С TSMB правда косяки были. При копировании чуток в начале зависали файлы и файл фильма не удалялся ни в какую с флешки. Установил старую SMB все заработало нормально.
12 минуты назад, MDP сказал:
там поди уже хотят ZFS
на smr дисках вредно ее хотеть.
а за exfat. я хотел. даже проголосовал там. но у меня не влезает в прошивку утилиты для работы с дисками. наверно смогу только посмотреть как читает... сериал только раздам. чтоб диск сменить.
Изменено пользователем Goblin
добавил
7 часов назад, Le ecureuil сказал:
Спасибо! Поставилось. Флешку определило. Только сегодня поставил. Пока никаких проблем...
9 часов назад, Le ecureuil сказал:
записал/прочитал один файлик, дальше не смотрел.
ЗЫ ntfs 2TB проверился секунд за 5 :)
12 минуты назад, r13 сказал:
На 2ТБ заняло пять минут(писал выше)
Потом проверил на 1ТБ за 15секунд.
Потом еще 4ТБ проверю, когда выйдет прошивка с фиксами
В 03.05.2020 в 22:54, Le ecureuil сказал:
Раздел без метки exfat и форматирование ntfs поправлены, в следующей сборке все будет ок.
3 часа назад, r13 сказал:
Зависит от размера MFT и количества файлов, свежесозданный раздел проверится мгновенно :)
20 минут назад, Le ecureuil сказал:
Полный но с видео, так что файлов относительно мало, поэтому и быстро )
exfat смонтировался вроде нормально. но когда начал с компа на него копировать... копирование зависло. уж не знаю на что грешить. на tsmb или на exfat. при тех же условиях на ntfs диск и с него копируется нормально.
Май 9 04:07:00 kernel usb 1-1: new high-speed USB device number 3 using ehci-platform
Май 9 04:07:00 kernel usb 1-1: New USB device found, idVendor=05e3, idProduct=0745
Май 9 04:07:00 kernel usb 1-1: Product: USB Storage
Май 9 04:07:00 kernel usb 1-1: SerialNumber: 000000000903
Май 9 04:07:00 kernel scsi1 : usb-storage 1-1:1.0
Май 9 04:07:03 kernel scsi 1:0:0:0: Direct-Access Generic STORAGE DEVICE 0903 PQ: 0 ANSI: 6
Май 9 04:07:03 kernel sd 1:0:0:0: Attached scsi generic sg0 type 0
Май 9 04:07:03 kernel sd 1:0:0:0: [sda] 3911680 512-byte logical blocks: (2.00 GB/1.86 GiB)
Май 9 04:07:03 kernel sd 1:0:0:0: [sda] Write Protect is off
Май 9 04:07:03 kernel sd 1:0:0:0: [sda] Mode Sense: 21 00 00 00
Май 9 04:07:03 kernel sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Май 9 04:07:03 kernel sda: sda1
Май 9 04:07:03 kernel sd 1:0:0:0: [sda] Attached SCSI removable disk
Май 9 04:07:03 ndm FileSystem::Ext: "/dev/sda" has an unknown partition type, ignored.
Май 9 04:07:03 ndm FileSystem::Ext: exfat "92BB-3A02:": filesystem initialized.
Май 9 04:07:03 kernel exFAT-fs (sda1[8:1]): trying to mount...
Май 9 04:07:03 kernel exFAT-fs (sda1[8:1]): utf8 enabled, "iocharset=iso8859-1" is recommended
Май 9 04:07:04 kernel exFAT-fs (sda1[8:1]): set logical sector size : 512
Май 9 04:07:04 kernel exFAT-fs (sda1[8:1]): (bps : 512, spc : 64, data start : 640, aligned)
Май 9 04:07:04 kernel exFAT-fs (sda1[8:1]): detected volume size : 1954816 KB (disk : 1955840 KB, part : 1954816 KB)
Май 9 04:07:04 kernel exFAT-fs (sda1[8:1]): mounted successfully!
Май 9 04:07:04 ndm FileSystem::Repository: "92BB-3A02:" registered.
да. подключал кард-ридер с microsd. :)
Форматнул флешку в exFAT:
(config)> opkg exfat format "EXT4 D4F79D:"
Synchronizing...
Копировал файлы на флешку:
И с флешки:
Все прошло хорошо. Копировалось туда и обратно по Wi-Fi. Флешка 2ГБ exFAT(отформатирована на роуторе), роутер GIGA III  версия ОС 2.16.D.3.0-4, компонент "Общий доступ к файлам и принтерам (TSMB CIFS beta)", ноут на Linux Mint 19.3 Tricia 64-разрядный.
