http://unit.nginx.org/
curl, перепакованный с опцией  --enable-unix-sockets: curl_7.61.0-3a_mipsel-3.4.ipk и libcurl_7.61.0-3a_mipsel-3.4.ipk
библиотека php: php7-lib_7.2.9-1_mipsel-3.4.ipk
сам пакет: nginx-unit_1.4-2_mipsel-3.4.ipk
пример работы:
~ # unitd --control 127.0.0.1:8443
~ # ps | grep unit
 4485 root      6144 S    {unitd} unit: main v1.4 [unitd --control 127.0.0.1:8443]
 4487 nobody   16388 S    {unitd} unit: controller
 4488 nobody    134m S    {unitd} unit: router
 4489 nobody   98.2m S    {unitd} unit: "example_php" application
 4490 nobody   80076 S    {unitd} unit: "example_php" application
 4491 nobody   34148 S    {unitd} unit: "example_python" application
 4492 nobody   13572 S    {unitd} unit: "example_python" application
 4493 nobody   36408 S    {unitd} unit: "example_python_3" application
 4495 nobody   15920 S    {unitd} unit: "example_python_3" application
 4496 nobody   33168 S    {unitd} unit: "example_perl" application
 4497 nobody   42732 S    {unitd} unit: "example_ruby" application
 4499 nobody   22248 S    {unitd} unit: "example_ruby" application
 5811 root      4780 S    grep unit
~ # curl 127.0.0.1:8443
	"certificates": {},
	"config": {
		"applications": {
			"example_php": {
				"type": "php",
				"user": "nobody",
				"processes": 2,
				"root": "/opt/share/www/unit-php/php-app",
				"index": "index.php"
			"example_python": {
				"type": "python 2.7",
				"user": "nobody",
				"processes": 2,
				"path": "/opt/share/www/unit-python2.7/python-app",
				"module": "wsgi"
			"example_python_3": {
				"type": "python 3.7",
				"user": "nobody",
				"processes": 2,
				"path": "/opt/share/www/unit-python3.7/python-app",
				"module": "wsgi"
			"example_perl": {
				"type": "perl",
				"user": "nobody",
				"processes": 1,
				"working_directory": "/opt/share/www/unit-perl/perl-app",
				"script": "/opt/share/www/unit-perl/perl-app/index.pl"
			"example_ruby": {
				"type": "ruby",
				"user": "nobody",
				"processes": 2,
				"script": "/opt/share/www/unit-ruby/ruby-app.ru"
		"listeners": {
			"*:8300": {
				"application": "example_php"
			"*:8400": {
				"application": "example_python"
			"*:8500": {
				"application": "example_python_3"
			"*:8600": {
				"application": "example_perl"
			"*:8700": {
				"application": "example_ruby"
~ # cat /opt/var/log/unit.log
2018/09/27 21:40:36 [info] 4486#4486 discovery started
2018/09/27 21:40:36 [notice] 4486#4486 module: perl 5.28.0 "/opt/lib/nginx/unit/perl.unit.so"
2018/09/27 21:40:36 [notice] 4486#4486 module: php 7.2.9 "/opt/lib/nginx/unit/php7.unit.so"
2018/09/27 21:40:36 [notice] 4486#4486 module: python 2.7.15 "/opt/lib/nginx/unit/python2.7.unit.so"
2018/09/27 21:40:36 [notice] 4486#4486 module: python 3.7.0 "/opt/lib/nginx/unit/python3.7.unit.so"
2018/09/27 21:40:36 [notice] 4486#4486 module: ruby 2.5.1 "/opt/lib/nginx/unit/ruby.unit.so"
2018/09/27 21:40:37 [info] 4487#4487 controller started
2018/09/27 21:40:37 [notice] 4485#4485 process 4486 exited with code 0
2018/09/27 21:40:37 [info] 4488#4488 router started
2018/09/27 21:40:37 [info] 4488#4488 OpenSSL 1.0.2p  14 Aug 2018, 1000210f
2018/09/27 21:40:37 [info] 4489#4489 "example_php" application started
2018/09/27 21:40:37 [info] 4489#4489 (non ABS_MODE) php root: "/opt/share/www/unit-php/php-app"
2018/09/27 21:40:37 [info] 4490#4490 "example_php" application started
2018/09/27 21:40:37 [info] 4490#4490 (non ABS_MODE) php root: "/opt/share/www/unit-php/php-app"
2018/09/27 21:40:37 [info] 4491#4491 "example_python" application started
2018/09/27 21:40:37 [info] 4492#4492 "example_python" application started
2018/09/27 21:40:38 [info] 4493#4493 "example_python_3" application started
2018/09/27 21:40:38 [info] 4495#4495 "example_python_3" application started
2018/09/27 21:40:38 [info] 4496#4496 "example_perl" application started
2018/09/27 21:40:39 [info] 4497#4497 "example_ruby" application started
2018/09/27 21:40:41 [info] 4499#4499 "example_ruby" application started
cannot handle ref type 15 at /opt/lib/perl5/5.28/Data/Dumper.pm line 208.
в картинках
