Добрый день!
Несколько дней подряд утром не работает телефон, в панели управления трубка исчезает.
В логах видны disabled by hub, затем находится.
Когда трубка исчезает - происходит вот такое:
[E] Jan 20 11:55:07 kernel: usb usb1-port1: disabled by hub (EMI?), re-enabling...
[I] Jan 20 11:55:07 kernel: usb 1-1: USB disconnect, device number 47
[I] Jan 20 11:55:07 nvox: No USB dongle.
[I] Jan 20 11:55:07 ndm: Nvox::Manager: Keenetic Plus DECT removed.
[I] Jan 20 11:55:07 kernel: usb 1-1: new full-speed USB device number 48 using xhci-mtk
[I] Jan 20 11:55:07 kernel: usb 1-1: New USB device found, idVendor=0586, idProduct=3428, bcdDevice= 0.00
[I] Jan 20 11:55:07 kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[I] Jan 20 11:55:07 kernel: usb 1-1: Product: Keenetic Plus DECT
[I] Jan 20 11:55:07 kernel: usb 1-1: Manufacturer: ZyXEL
[I] Jan 20 11:55:07 kernel: usb 1-1: SerialNumber: ....skip.....
[I] Jan 20 11:55:07 ndm: Nvox::Manager: Keenetic Plus DECT added.
[E] Jan 20 11:55:10 kernel: usb usb1-port1: disabled by hub (EMI?), re-enabling...
[I] Jan 20 11:55:10 kernel: usb 1-1: USB disconnect, device number 48
[I] Jan 20 11:55:10 ndm: Nvox::Manager: Keenetic Plus DECT removed.
[I] Jan 20 11:55:10 kernel: usb 1-1: new full-speed USB device number 49 using xhci-mtk
[I] Jan 20 11:55:11 kernel: usb 1-1: New USB device found, idVendor=0586, idProduct=3428, bcdDevice= 0.00
[I] Jan 20 11:55:11 kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[I] Jan 20 11:55:11 kernel: usb 1-1: Product: Keenetic Plus DECT
[I] Jan 20 11:55:11 kernel: usb 1-1: Manufacturer: ZyXEL
[I] Jan 20 11:55:11 kernel: usb 1-1: SerialNumber: ....skip.....
[I] Jan 20 11:55:11 ndm: Nvox::Manager: Keenetic Plus DECT added.
[I] Jan 20 11:55:11 kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd ndm rqt 128 rq 6 len 28 ret -110
[I] Jan 20 11:55:11 nvox: libusb-1.0 submit_transfer failed with error -4 (LIBUSB_ERROR_NO_DEVICE)
[I] Jan 20 11:55:11 nvox: fatal error in Libusb100UsbDriver.cpp:220
[I] Jan 20 11:55:12 kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd ndm rqt 128 rq 6 len 28 ret -110
[C] Jan 20 11:55:12 ndm: Usb::Device: "Keenetic Plus DECT": system failed [0xcffd00b1], operation timed out.
[E] Jan 20 11:55:12 ndm: Usb::Device: invalid string descriptor.
[E] Jan 20 11:55:12 ndm: Usb::Device: could not read description strings.
[I] Jan 20 11:55:12 kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd ndm rqt 128 rq 6 len 9 ret -110
[I] Jan 20 11:55:13 kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd ndm rqt 128 rq 6 len 9 ret -110
[C] Jan 20 11:55:13 ndm: Usb::Device: "Keenetic Plus DECT": system failed [0xcffd00b1], operation timed out.
[E] Jan 20 11:55:13 ndm: Usb::Device: invalid configuration descriptor: 0.
[W] Jan 20 11:55:13 ndm: Usb::Device: failed to get configuration header.
[I] Jan 20 11:55:15 kernel: usb 1-1: USB disconnect, device number 49
[I] Jan 20 11:55:15 ndm: Nvox::Manager: Keenetic Plus DECT removed.
[I] Jan 20 11:55:16 kernel: usb 1-1: new full-speed USB device number 50 using xhci-mtk
[I] Jan 20 11:55:17 kernel: usb 1-1: New USB device found, idVendor=0586, idProduct=3428, bcdDevice= 0.00
[I] Jan 20 11:55:17 kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[I] Jan 20 11:55:17 kernel: usb 1-1: Product: Keenetic Plus DECT
[I] Jan 20 11:55:17 kernel: usb 1-1: Manufacturer: ZyXEL
[I] Jan 20 11:55:17 kernel: usb 1-1: SerialNumber: ....skip.....
[I] Jan 20 11:55:17 ndm: Nvox::Manager: Keenetic Plus DECT added.
[I] Jan 20 11:55:17 ndm: Nvox::Manager: handset id "1" registered.
[I] Jan 20 11:55:17 ndm: Nvox::Manager: found new DECT dongle.
[I] Jan 20 11:55:17 ndm: Core::System::StartupConfig: saving (event).
[I] Jan 20 11:55:17 ndm: Nvox::Manager: handset id "1" removed.
[I] Jan 20 11:55:17 nvox: Line SIPNET (TLS): sipnet.ru registration failed: response 503 Address not available.
[I] Jan 20 11:55:21 ndm: Core::System::StartupConfig: configuration saved.
Подскажите пожалуйста - куда копать
Изменено пользователем ldmi
