Почему то на роутере Keenetic с белым IP TCP трафик работает форвард портов, а UDP нет
На внешнем компьютере делаю тест TCP и UDP трафика, один проходит, другой нет
Mac % iperf3 -c 95.xx.xx.xx -p 8082
Connecting to host 95.xx.xx.xx, port 8082
[  5] local 192.168.1.54 port 60140 connected to 95.xx.xx.xx port 8082
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.01   sec   128 KBytes  1.04 Mbits/sec
Mac % iperf3 -c 95.xx.xx.xx -p 8082 -u
iperf3: error - unable to read from stream socket: Resource temporarily unavailable
На сервере
Keenetic # iperf3 -s -p 8080
Server listening on 8080 (test #1)
Accepted connection from 78.xx.xx.76, port 53697
[  5] local 127.0.0.1 port 8080 connected to 78.xx.xx.76 port 53964
[  5]   0.00-1.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   1.00-2.00   sec   256 KBytes  2.10 Mbits/sec
[  5]   2.00-3.00   sec   256 KBytes  2.10 Mbits/sec
[  5]   3.00-4.00   sec   512 KBytes  4.20 Mbits/sec
[  5]   4.00-5.00   sec   384 KBytes  3.14 Mbits/sec
[  5]   5.00-6.00   sec   384 KBytes  3.15 Mbits/sec
[  5]   6.00-7.00   sec   768 KBytes  6.29 Mbits/sec
[  5]   7.00-8.00   sec  1.25 MBytes  10.5 Mbits/sec
[  5]   8.00-9.00   sec  1.12 MBytes  9.44 Mbits/sec
[  5]   9.00-10.00  sec  1.25 MBytes  10.5 Mbits/sec
[  5]  10.00-10.16  sec   256 KBytes  12.8 Mbits/sec
[  5]   0.00-10.16  sec  6.38 MBytes  5.26 Mbits/sec                  receiver
Server listening on 8080 (test #2)
Accepted connection from 78.xx.xx.76, port 54600
[  5] local 95.xx.xx.xx port 8080 connected to 78.xx.xx.xx port 53886
[ ID] Interval           Transfer     Bitrate         Jitter    Lost/Total Datagrams
[  5]   0.00-1.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   1.00-2.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   2.00-3.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   3.00-4.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   4.00-5.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   5.00-6.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   6.00-7.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   7.00-8.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   8.00-9.00   sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]   9.00-10.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  10.00-11.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  11.00-12.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  12.00-13.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  13.00-14.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  14.00-15.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  15.00-16.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  16.00-17.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  17.00-18.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  18.00-19.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  19.00-20.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  20.00-21.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  21.00-22.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  22.00-23.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  23.00-24.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  24.00-25.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  25.00-26.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  26.00-27.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  27.00-28.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  28.00-29.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
[  5]  29.00-30.00  sec  0.00 Bytes  0.00 bits/sec  0.000 ms  0/0 (0%)
Сам пророс порта с 8082 на 8image.thumb.png.2d61e4a8a290532f2f2644793eae8fbd.png080 настроен
Ответов пока нет
